for the watering of my balcony plants I have the following simple automation which switches my Gardena smart water control pump on and after a certain amount of time off again.
alias: Balkonbewässerung Zeitplan
description: ''
- platform: time
at: '08:00:00'
condition: []
- service: switch.turn_on
data: {}
entity_id: switch.balkon_bewasserung
- delay:
hours: 0
minutes: 4
seconds: 0
milliseconds: 0
- service: switch.turn_off
data: {}
mode: single
The automation has worked since recently. Now, Trace Timeline gives the following error message:
Stopped because an error was encountered at 28. September 2023 um 08:00:05 (runtime: 5.15 seconds)
Consequence is that the water pump does not switch off and runs for an indefinte amount of time. Therefore, I have another backup automation for switching the water pump off again. Quite annoying.
The logs for the automation above (“Balkonbewässerung Zeitplan”) are as follows:
Logger: homeassistant.components.automation.balkonbewasserung_zeitplan
Source: custom_components/gardena_smart_system/switch.py:144
Integration: Automatisierung (documentation, issues)
First occurred: 27. September 2023 um 08:00:05 (4 occurrences)
Last logged: 08:00:05
Balkonbewässerung Zeitplan: Error executing script. Unexpected error for call_service at pos 1:
While executing automation automation.balkonbewasserung_zeitplan
File "/usr/local/lib/python3.11/site-packages/anyio/streams/tls.py", line 131, in _call_sslobject_method
result = func(*args)
File "/usr/local/lib/python3.11/ssl.py", line 921, in read
v = self._sslobj.read(len)
ssl.SSLWantReadError: The operation did not complete (read) (_ssl.c:2580)
File "/usr/local/lib/python3.11/site-packages/httpcore/_backends/anyio.py", line 34, in read
return await self._stream.receive(max_bytes=max_bytes)
File "/usr/local/lib/python3.11/site-packages/anyio/streams/tls.py", line 196, in receive
data = await self._call_sslobject_method(self._ssl_object.read, max_bytes)
File "/usr/local/lib/python3.11/site-packages/anyio/streams/tls.py", line 138, in _call_sslobject_method
data = await self.transport_stream.receive()
File "/usr/local/lib/python3.11/site-packages/anyio/_backends/_asyncio.py", line 1203, in receive
await self._protocol.read_event.wait()
File "/usr/local/lib/python3.11/asyncio/locks.py", line 213, in wait
await fut
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.11/site-packages/httpcore/_exceptions.py", line 10, in map_exceptions
yield
File "/usr/local/lib/python3.11/site-packages/httpcore/_backends/anyio.py", line 32, in read
with anyio.fail_after(timeout):
File "/usr/local/lib/python3.11/site-packages/anyio/_core/_tasks.py", line 119, in __exit__
raise TimeoutError
TimeoutError
File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 60, in map_httpcore_exceptions
yield
File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 353, in handle_async_request
resp = await self._pool.handle_async_request(req)
File "/usr/local/lib/python3.11/site-packages/httpcore/_async/connection_pool.py", line 262, in handle_async_request
raise exc
File "/usr/local/lib/python3.11/site-packages/httpcore/_async/connection_pool.py", line 245, in handle_async_request
response = await connection.handle_async_request(request)
File "/usr/local/lib/python3.11/site-packages/httpcore/_async/connection.py", line 96, in handle_async_request
return await self._connection.handle_async_request(request)
File "/usr/local/lib/python3.11/site-packages/httpcore/_async/http11.py", line 121, in handle_async_request
raise exc
File "/usr/local/lib/python3.11/site-packages/httpcore/_async/http11.py", line 99, in handle_async_request
) = await self._receive_response_headers(**kwargs)
File "/usr/local/lib/python3.11/site-packages/httpcore/_async/http11.py", line 164, in _receive_response_headers
event = await self._receive_event(timeout=timeout)
File "/usr/local/lib/python3.11/site-packages/httpcore/_async/http11.py", line 200, in _receive_event
data = await self._network_stream.read(
File "/usr/local/lib/python3.11/site-packages/httpcore/_backends/anyio.py", line 31, in read
with map_exceptions(exc_map):
File "/usr/local/lib/python3.11/contextlib.py", line 155, in __exit__
self.gen.throw(typ, value, traceback)
File "/usr/local/lib/python3.11/site-packages/httpcore/_exceptions.py", line 14, in map_exceptions
raise to_exc(exc) from exc
httpcore.ReadTimeout
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 468, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 704, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 666, in _async_run_long_action
return long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1969, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2006, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 235, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 870, in entity_service_call
response_data = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 942, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1253, in async_turn_on
await self.hass.async_add_executor_job(ft.partial(self.turn_on, **kwargs))
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/gardena_smart_system/switch.py", line 144, in turn_on
).result()
File "/usr/local/lib/python3.11/concurrent/futures/_base.py", line 456, in result
return self.__get_result()
File "/usr/local/lib/python3.11/concurrent/futures/_base.py", line 401, in __get_result
raise self._exception
File "/usr/local/lib/python3.11/site-packages/gardena/devices/water_control.py", line 34, in start_seconds_to_override
await self.location.smart_system.call_smart_system_service(self.valve_id, data)
File "/usr/local/lib/python3.11/site-packages/gardena/smart_system.py", line 100, in call_smart_system_service
r = await self.client.put(
File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1885, in put
return await self.request(
File "/usr/local/lib/python3.11/site-packages/authlib/integrations/httpx_client/oauth2_client.py", line 90, in request
return await super(AsyncOAuth2Client, self).request(
File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1530, in request
return await self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1617, in send
response = await self._send_handling_auth(
File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1645, in _send_handling_auth
response = await self._send_handling_redirects(
File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1682, in _send_handling_redirects
response = await self._send_single_request(request)
File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1719, in _send_single_request
response = await transport.handle_async_request(request)
File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 352, in handle_async_request
with map_httpcore_exceptions():
File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 77, in map_httpcore_exceptions
raise mapped_exc(message) from exc
httpx.ReadTimeout
Does anyone have a clue what the problem is here?
Thank you!
