New to HA (migrating from UDI/ISY; Hoping to setup a simple automation that turns on all my at sunset based on their labels - so I don’t have to go back and update the automation every time I add/update a switch or outdoor device? I have about a dozen s so far out of several hundred devices in the config.
I have all my outdoor lights configured with a label and was hoping I could do a simple automation to turn them all on at sunset/ and one for turning them all off at sunrise?
What i did was to put all lights (for a room say) in a group and control the group. The other advantage is that it is easy to swap out a light if it is faulty just by modifiying the group members.
#automations.yaml
- id: 'outdoor_light_label_sunrise_sunset_0001'
alias: "Outdoor Lights Sunrise/Sunset"
description:
- alias: Sunset trigger
platform: numeric_state
entity_id: sun.sun
attribute: elevation
below: 0
- alias: Sunrise trigger
entity_id: sun.sun
above: 0
condition: []
- service: homeassistant.turn_{{ trigger.id }}
label_id: my_example_label
data: {}
If all your entities are in the same domain i.e. light
or switch
you can use the domain-specific service, but to keep it so that it will work across the board you need to use the generic services as shown above.
Thank you - trying that using my label “Outdoor Lights”. I just paste that to the end of the “configuration.yaml”?
My lights are a variety of lights, switches, outlets, and plug-ins so I like having just the one entry to track!
No, it is better to put it into automations.yaml
so that it is editable from the frontend. I have edited to configuration above so that it should work in automations.yaml
You can also create your automation in the GUI Automation Editor and just use the configuration above as a roadmap.
