I am new to home assistant, still trying to figure it all out. I want to create an automation that will turn off after ten minutes.
Can anybody help or advise how to add it to this?
Thank you
alias: Landing Motion
description: ""
- type: motion
platform: device
device_id: 41f95856991320032c484d37b9f427a2
entity_id: binary_sensor.landing_motion_occupancy
domain: binary_sensor
condition:
- condition: time
after: "17:00:00"
before: "08:30:00"
weekday:
- sun
- sat
- fri
- thu
- wed
- tue
- mon
- type: turn_on
device_id: 774d9a0815f8b2abbadcf741d712d6fb
entity_id: light.stairs
domain: light
flash: short
brightness_pct: 50
mode: single
reef-actor
(Reef Actor)
August 15, 2022, 10:41pm
2
You might want to use the Wait For Trigger action
wait_for_trigger:
- platform: state
to: 'off'
You can add a for:
to that to wait for ten minutes
I am so bad at this lol
so I tried changing it a few ways and can’t get it right.
I was thinking something like this, because in my mind it would step through it. but home assistant won’t accept it
description: ""
- type: motion
platform: device
condition:
- condition: state
entity_id: sensor.landing_motion_illuminance_lux
attribute: unit_of_measurement
- type: turn_on
domain: light
flash: short
brightness_pct: 50
wait_for_trigger:
- platform: state
to: 'off'
- type: turn_off
domain: light
flash: short
brightness_pct: 50
mode: single
calisro
(Rob)
August 16, 2022, 11:25pm
5
This is probably more complicated than you’d like. But I am pasting it because I think it helps to look at other’s code sometimes to help your own. I don’t like to use ‘waits’ in the code for longer periods of time because they don’t persist a home assistant restart nor a ‘automation reload’ (you saving ANY automation) and will cancel those waits… So be careful using them.
Here, I am using a timer to count down the shuttting off the light. So after the last motion of ‘x’ minutes, it will shut off my office light. If there’s more motion within that time, it will restart the timer.
alias: Front Office Motion Light
description: ""
- platform: state
entity_id:
- binary_sensor.front_office_motion
to: "on"
- platform: event
event_type: timer.finished
event_data:
entity_id: timer.front_office_timer
condition: []
- variables:
light: light.front_office_light
timer: timer.front_office_timer
night: >-
{% if now() >
now().replace(hour=21).replace(minute=0).replace(second=0).replace(microsecond=0)
or now() < now().replace(hour=7).replace(minute=0).replace(second=0).replace(microsecond=0) %}
true
{% else %}
false
{% endif %}
duration: "{% if night == 'true' %}240{% else %}1800{% endif %}"
brightness: "{% if night == 'true' %}20{% else %}100{% endif %}"
- choose:
- conditions:
- condition: trigger
sequence:
- choose:
- conditions:
- condition: template
value_template: "{{ is_state(timer,'idle') }}"
value_template: "{{ is_state(light,'off') }}"
sequence:
- service: light.turn_on
brightness_pct: "{{brightness}}"
entity_id: "{{light}}"
default: []
- service: timer.start
duration: "{{ duration | int }}"
entity_id: "{{timer}}"
- conditions:
sequence:
- service: light.turn_off
default: []
mode: single
Also, the reason the editor wouldn’t ‘take’ yours is it isn’t valid yaml. This would be valid…
description: ""
- type: motion
platform: device
condition:
- condition: state
- type: turn_on
domain: light
flash: short
brightness_pct: 50
- wait_for_trigger:
- platform: state
to: "off"
- type: turn_off
domain: light
flash: short
brightness_pct: 50
mode: single
Although you probably should have a timeout for hte wait_for_trigger…
Thank you so much for that. It really has been most helpful. learning as I go.
123
(Taras)
August 17, 2022, 1:27pm
7
It’s possible to simplify a few templates:
night: "{{ now().hour > 21 or now().hour < 7 }}"
duration: "{{ iif(night, 240, 1800) }}"
brightness: "{{ iif(night, 20, 100) }}"
This would go in the conditions section?
calisro
(Rob)
August 17, 2022, 3:07pm
9
He was just simplifying the variables. To look like this:
description: ""
- platform: state
entity_id:
to: "on"
- platform: event
event_data:
condition: []
- variables:
- choose:
- conditions:
sequence:
- choose:
- conditions:
sequence:
default: []
- conditions:
sequence:
default: []
mode: single
