So,
i have a very simple automation, if I trigger it via the menu in hassio, it works fine, but for any reason it does not work in real time.
Before the update to 0.68, it worked.
I jumped from 0.66.x to 0.68 straight.
Again, if I trigger it via hand, it turns off the printer, so the command to turn off is working fine and the names are correct too.
The only think I can imagine is that the sensor.sensor.octoprint_job_percentage is not seen correctly, but in the UI I can see the same percentage as on the printer.
- alias: Printer done, turn off
- platform: state
entity_id: sensor.octoprint_job_percentage
to: '100.0'
- delay: 00:00:30
- service: switch.turn_off
entity_id: switch.tplink_switch
Any ideas where to check why its not working.?
Oh, and the automation is enabled
Regards
Crey
