I have a set of very simple automations that is generation more errors that I can believe. The job is to generate a simple html command send. It works often, but fails often as well. The errors seemed to start with either 64.3 or 65.0, not sure which. I am currently running on 65.2.
I have imaged 3 different cards and the issue persists. 2 of the cards were new Sandisk Ultra 16gb cards. I have a couple more cards on the way and a much more modern writer. Running on an RPi 2 with no lag or performance issues apparent.
These update 1 ESPEasy device that displays the data and passes it on to others via ESPEasy global sync. I have staggered the trigger times thinking that maybe it was just to much i/o in one burst. This did not change the behavior at all. They all execute perfectly on the command line. I am seeing a second error in conjunction with these errors, see below.
- id: "Broadcast Real Temp HTTP"
alias: 'Broadcast Real Temp HTTP'
initial_state: 'on'
hide_entity: false
- platform: time
minutes: '/2'
seconds: '30'
- service: shell_command.wu_temp_http
data_template:
state: '{{ states.sensor.pws_temp_f.state }}'
- id: "Broadcast Feels Like Temp HTTP"
alias: 'Broadcast Feels Like Temp HTTP'
initial_state: 'on'
hide_entity: false
- platform: time
minutes: '/2'
seconds: '45'
- service: shell_command.wu_fl_http
data_template:
state: '{{ states.sensor.pws_feelslike_f.state }}'
- id: "Broadcast Humidity HTTP"
alias: 'Broadcast Humidity HTTP'
initial_state: 'on'
hide_entity: false
- platform: time
minutes: '/3'
seconds: '0'
- service: shell_command.wu_humidity_http
data_template:
state: '{{ states.sensor.pws_relative_humidity.state }}'
- id: "Broadcast Wind HTTP"
alias: 'Broadcast Wind HTTP'
initial_state: 'on'
hide_entity: false
- platform: time
minutes: '/3'
seconds: '15'
- service: shell_command.wu_wind_http
data_template:
state: '{{ states.sensor.pws_wind_mph.state }}'
- id: "Broadcast Gust HTTP"
alias: 'Broadcast Gust HTTP'
initial_state: 'on'
hide_entity: false
- platform: time
minutes: '/3'
Error running command: `/usr/bin/curl "http://192.168.1.121/control?cmd=event,FeelsLike={{state}}"`, return code: -11
7:30 PM /usr/lib/python3.6/site-packages/homeassistant/components/shell_command.py (ERROR)
Error running command: `/usr/bin/curl "http://192.168.1.121/control?cmd=event,WindDeg={{state}}"`, return code: -11
7:27 PM /usr/lib/python3.6/site-packages/homeassistant/components/shell_command.py (ERROR)
Error running command: `/usr/bin/curl "http://192.168.1.121/control?cmd=event,Wind={{state}}"`, return code: -11
Error in database connectivity: (sqlite3.OperationalError) disk I/O error (Background on this error at: http://sqlalche.me/e/e3q8). (retrying in 3 seconds)
7:12 PM components/recorder/__init__.py (ERROR)
Error executing query: (sqlite3.OperationalError) disk I/O error (Background on this error at: http://sqlalche.me/e/e3q8)
7:12 PM components/recorder/util.py (ERROR)
