blueprint:
name: Test Blueprint
domain: automation
input:
selector:
entity:
domain:
- input_number
multiple: false
variables:
sensor: !input sensor
value_template: "{{ (states(sensor) | float >= 800) }}"
- service: homeassistant.toggle
entity_id: light.test
alias: Test Automation
description: ""
use_blueprint:
path: ABOVE BLUEPRINT PATH
input:
sensor: input_number.test
Hello, I have created a blueprint and an automation as shown above.
I want to adjust the input_number.test
so that the automation is triggered when it is above 800, but the trigger does not work.
I think the problem is using the sensor
variable in the value_template
It works well when I change the sensor
to ‘input_number.test’
What is the problem?
