Simple blueprint for ZHA Tuya 1 Button switch ( TS0041 TZ3000_mrpevh8p )
Hi all. I bought cheap Zigbee buttons ( This sort of thing: https://www.aliexpress.com/item/1005006401590560.html ) that seem to be very similar to other Tuya devices, but I could not get modifications of existing blueprints to work. After a lot of learning and debugging I found that even if you have a condition that switches on the “command” field of the Zigbee data if the button send two different events very quickly on press, ZHA would get confused and put the target device into a “stuck” state until some until the light.toggle service was called twice. However, if you put the full condiditon in the “trigger” clause then the second event is never processed and the target device does not get stuck, so here is my blueprint for simple light toggle using these buttons.
blueprint:
  name: ZHA - TS0041 Scene Switch
  description: Automate your Tuya 1-Button Scene Switch using ZHA events.
  domain: automation
  input:
    tuya_1button_scene_switch:
      description: Tuya 1-Button Scene Switch to use
      selector:
        device:
          integration: zha
          manufacturer: _TZ3000_mrpevh8p
          model: TS0041
    button_short_press:
      description: Action to run on a short Press
      default: []
      selector:
        action: {}
mode: restart
- platform: event
  event_type: zha_event
  event_data:
    device_id: !input 'tuya_1button_scene_switch'
    command: remote_button_short_press
  sequence: !input 'button_short_press'
Hi SilentMobius,
Thank you for your contribution to the community!
I have a suggestion for you. People will be asking for the my- link to easy load your code, use this you set that up.
Create a link – My Home Assistant
Just in case, here is the import button for Zigbee2MQTT Tuya 1-button smart button:
This expect an entity and my TS0041 only is published as a device, should I make another helper?
Imported this today and I don’t see my automation getting triggered at all… did you manage to get it to work?
I had also problems to get it working, so i created my own blueprint, specifically for Zigbee2MQTT users who have enabled the new experimental_event_entities option.
Check it out:
Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint URL.
