Simple calibration
I have this as standard configuration for an ESP32 Devkit1 with a BMP180 breakout.
# Example configuration entry
  - platform: bmp085
    temperature:
      name: "Outside Temperature"
    pressure:
      name: "Outside Pressure"
    update_interval: 30s
What I would like to achieve is a numeric calculation, which I can adjust as necessary, to offset or more accurately calibrate the readings displayed.
Example, for me the calculation should be something logical like
temperature = temperature(name) * Offset
This assumes the sensor offset is linear and single point is all that’s required, which I doubt, but it’s a good starting point for me.
Me being a complete n00b to yaml, anyone got a pointer for me as to coding and implementation?
My hours to dedicate to this are pretty limited, hence the question after not much rummaging.
This section of the docs lists a number of filters you can apply to any sensor. Sensor Component — ESPHome
Fantastic, just the nudge I ws hoping for, thanks nickrout!
