crash is overly broad.
Please describe in details the symptoms.
OK, by âcrashâ i mean I come around the corner and my garage door doesnât open. I check HA and it will/can not connect. I try to turn on an emulated Hue switch with my Harmony remote. Nothing happens. I check HA and it can/will not connect. I go to my desktop and try to load my local HA URL. Nothing. It simply stops working and I have to pull the power plug and reconnect to get it to reboot.
Do you have samba share set up or ssh? Without seeing the logs thereâs not much that can be said
Yup. I can pull whatever logs youâd like. I canât see anything in them that helps me but Iâm no expert. Which would you like to see?
Home assistant logs
Under Supervisor? I have several options, the most useful being Supervisor and Core. Which specify and from where?
home-assistant.log in your configuration folder.
Not much help, but hereâs what it said:
2021-07-26 10:53:17 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alarmdotcom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant 2021-07-26 10:53:17 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant 2021-07-26 10:53:17 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant 2021-07-26 10:53:17 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant 2021-07-26 10:53:58 WARNING (MainThread) [slixmpp.stringprep] Using slower stringprep, consider compiling the faster cython/libidn one. 2021-07-26 10:54:00 WARNING (MainThread) [slixmpp.basexmpp] Legacy XMPP 0.9 protocol detected. 2021-07-26 10:54:24 ERROR (Recorder) [homeassistant] Error doing job: Task was destroyed but it is pending!
Iâve traced this to an OOM issue stemming from the Ring integration.
Hello. I am having quite similar and still not solved issue in post by same author: Home Assistant just stops working!
@bkr1969 , how did you traced this to particular integration?
Also was samba working after system was crashed? As for me it does not. Neither samba, or ssh
This is a really old issue. Many people had a memory leak issue with Ring. I believe it is resolved now. No idea about Samba as I had to completely restart my system after each crash.
Youâll notice in all those threads that youâre linking to that there is a common solution: Get a good quality SD card or switch to an SSD.
If all your containers are dying, then something is wrong with your system. 9 times out of 10 if youâre on a raspberry pi itâs the sd card, 1/10 times itâs a cheap power supply.
Thanks both @bkr1969 and @petro
Most frustrating part is that I donât know how to troubleshoot this issue, as when it happens I cannot access log files.
Power cycle recreates those files
From hardware perspective: I have RPI4 model B 4GB ram (official power supply) with SSD in USB enclosure connected via USB and a first generation Conbee stick.
Always installing latest stable OS and Core versions
My addons:
AppDaemon 4,Duck DNS,File editor,Mosquitto broker,Plex Media Server ,Portainer,SQLite Web,SSH & Web Terminal (Itâs not running),Samba share,Terminal & SSH,deCONZ
Like initial post author I mostly get these issues weekly or couple times a week. But itâs not exactly one week after restart.
Integrations:
when you restart, your old HA logs should still be in tact. FWIW: The differences between my system and your system are:
Addons:
- AppDaemon 4 (however I ran it for years, probably not the issue.)
- File editor
- SQLite Web
- deCONZ
- Plex Media Server
- Maybe Portainer (I havenât updated it because I donât want to create a login).
Integrations:
- Daiken AC
- Daiken
- deCONZ
- Meteorologisk
- NordPool
- OpenWeatherMap
- Xiaomi Mio
So Iâd start by looking at those. Other than that, itâs going to be hard to track down your issue.
Thanks!
Is it possible that itâs just raspberry hardware error and RPi needs replacement?
I can also try disabling ones with differences. Disable one by one and check. Is disabling enough or I would need to remove add-ons / integrations?
The only I cannot disable for longer then a few hours is deconz as itâs responsible for all ZigBee devices and home heating
As the âstandardâ issues with this kind of error messages is the SD-card or the power supply, can you check how much current is taken from the power supply? I could imagine, that a combination of things could bring the power supply to its knees or at least near itâŚ
I wouldnât start with disabling, before I ruled out all other pointers (SD and power). There are way to many people out there, that run a similar combination of things without problems. So Iâd suspect something âfaultyâ. Not faulty in general, but faulty enough, to sometimes bow outâŚ
Just a small story: I once built up a PC from pieces and it worked great. Only sometimes it restarted without any errors or things like that. Took us a while to find out, that it always restarted when someone touched the case. But even with knowing this, it took us nearly a week. We tested everything, from OS to components and whatsoever. In the end we dismantled it completely, just to find out, one (1!) out of over 20 insulating rings between main board and case was missing⌠What I want to say is this, if the majority runs the same combinations of hardware without errors, it is more likely, that something with the hardware is faulty, than with the software.
