I have seen several entries about this and similar topics, but have not seen an positive (to me ) answer.
I need a new doorbell. My current one - a 433MHz, has decided to give up.
There is no power near the door⌠so an easy solution with a ESP32 is out of the question⌠and I donât feel like cabling to the doorâŚ
I have a lot of zWave devices (door windows and thermostats), so this works fine. I have a Sonos speaker connected, so when my windows have been open to long, sonos says its time to closeâŚ
So, in my small naive world, I had hoped to find a âz-waveâ button, that I could include in the network, and have it say on sonos when it is being pushed/when someone is at the doorâŚ
But I canât find any zwave buttons⌠not simple ones with just âoneâ button.
What can you recommend ?
Guess I could make something out of a door/window sensorâŚ
I opened up a ZigBee door sensor and soldered an old-fashioned doorbell to the reed switch. The advantage is it actually looks like a doorbell rather than a nondescript smart button. I assume you could do the same with Z-Wave. I chose a sensor rather than a switch because the large reed switch means thereâs plenty of room for my crappy soldering skills.
Since you donât have Zigbee, youâre unlikely to like my solution, but I just use a Xiaomi smart button, looks alot like a doorbell and battery powered. Mineâs under a sheltered area, so far itâs survived outdoors.
Iâm using an Amazon Dash button (wifi) with the Dasshio addon, so far has been working perfect for the past year.
I triggers TTS to all the Google Home Miniâs in the house.
