Simple generic thermostat automation
Hello to everyone, I’m new to hass.io and the automation world, but more and more fascinated by the possibilities that can be achieved with this technology. I searched on diverse forums and I put some automation together.
I’m using Home Assistant 2021.3.4 on a Raspberry PI4
I have to automate a simple smart socket in which is plugged a fan heater which has to turn off above 20 degrees and on when it goes above 20. this heater is in my cellar and only has to function when I’m in the cellar. The onboard thermostat isn’t efficient. Smart socket and thermostat both are visible on hass.io.
Any help is much appreciated
I tried two simple automations
- id: '1617816225341'
  alias: accendi stufetta sotto 20 gradi
  description: ''
  - platform: numeric_state
    entity_id: switch.bf74f7f87c5e736bc5i80w
    value_template: '{{ state.attributes.current_temperature }}'
    above: '8'
    below: '20'
  condition:
  - condition: device
    type: is_on
    device_id: f3626e048d86450c33189d59b86c79c5
    entity_id: switch.bf71ebbb368150db14rr4g
    domain: switch
  - type: turn_on
    device_id: c074f210f476d6c6045020ca65958a8c
    entity_id: switch.bf921f944d22c65e0ehuvq
    domain: switch
  mode: single
the automation will function only if the other smart socket in the room (pc) is enabled, that means I’m at the computer.
- id: '1617817886648'
  alias: spegni stufetta a 20,5 gradi
  description: ''
    above: '20.5'
  condition: []
  - type: turn_off
    domain: switch
  mode: single
this automation seems not to work.
Scrap these and set up a generic thermostat integration
It’s built into home assistant. No need to make your own automations.
