Hello all,
Can you please help me with a simple YAML script? I am beginner with YAML and I need a reference on this:
sequence:
- variables:
output_text: this is a text
- if:
- condition: state
entity_id: binary_sensor.boolean
state: "off"
then:
output_text = output_text + added text <===This is the part that I am struggling
sequence:
- variables:
- if:
- condition: state
state: "off"
then:
- variables:
output_text: "{{ output_text }} added text"
Be advised that due to scoping rules, the second output_text variable is not the first output_text variable. It has the same name but it’s a different variable whose scope is limited to within the if then statement.
Here’s what I mean:
sequence:
- variables:
# Value of output_text outside of the `if then` is "this is a text"
- if:
- condition: state
state: "off"
then:
- variables:
# Value of output_text inside the `if then` is "this is a text added text"
I would need to know more about your intended application in order to make alternative suggestions. For example, here’s another way to make decisions about a variable’s value:
sequence:
- variables:
output_text: >
{% set x = 'this is a text' %}
{{ iif(is_state('binary_sensor.boolean', 'off'), x, x ~ 'added text') }}
Thank you for your response! I am trying to make a “Home health check”.
I wanna start by a notification “Health check starting” and then the rest of the readings.
I know that I can just make partial notifications instead of adding them all up and reading it.
I just wanted to make it for sake of being able to make it. To learn some basics more.
So from what I gathered on the document which you showed me, I need to keep reminding myself that YAML is actually a mark up language, not an full blown programming language.
thank you very much
