Simple Historic and real time Internet Traffic from SNMP (dd-wrt)
Hi there!
I just want a simple historical graphic and a real time indicator of my inbound / outbound bps readings out of an AP with dd-wrt with snmp.
I know nothing about yaml and a bit of coding so right now it is a trial and error approach with a 100% error rate.
I am able to “get” the info properly and this is how I see it:
console>snmputil get .1.3.6.1.2.1.2.2.1.10.7
Variable = interfaces.ifTable.ifEntry.ifInOctets.7
Value = Counter32 1117057065
console>snmputil get .1.3.6.1.2.1.2.2.1.16.7
Variable = interfaces.ifTable.ifEntry.ifOutOctets.7
Value = Counter32 3622501640
sensors are set this way…
  - platform: snmp
    host: !secret fwhost
    community: !secret heavendoor_snmp-community
    baseoid: .1.3.6.1.2.1.2.2.1.10.7
    default_value: 0
    accept_errors: true
    version: 2c
    unit_of_measurement: bps
    scan_interval: 15
  - platform: snmp
    baseoid: .1.3.6.1.2.1.2.2.1.16.7
    default_value: 0
    accept_errors: true
    version: 2c
    scan_interval: 15
I basically followed the instructions here:
But the automation is failing.
Automation looks like this:
alias: Internet Bandwidth
description: ""
  - platform: time_pattern
    seconds: /15
condition: []
  - parallel:
      - service: input_number.set_value
        entity_id: input_number.inbound_memory
        data_template:
          value: "{{ states('sensor.heavendoor_snmp_wan_in') | float | round(2) }}"
        entity_id: input_number.outbound_memory
        data_template:
          value: "{{ states('sensor.heavendoor_snmp_wan_out') | float | round(2) }}"
      - delay:
          hours: 0
          minutes: 0
          seconds: 1
          milliseconds: 0
        entity_id: input_number.inbound_bandwidth
        data_template:
          value: >-
            {{ ((( (states('sensor.heavendoor_snmp_wan_in') | float | round(2)) -
            (states('input_number.inbound_memory') | float | round(2))) * 8 *
            1000) / (15*1000000000)) | float | round(2) }}
        entity_id: input_number.outbound_bandwidth
        data_template:
          value: >-
            {{ ((( (states('sensor.heavendoor_snmp_wan_out') | float | round(2)) -
            (states('input_number.outbound_memory') | float | round(2))) * 8 *
mode: single
… but it fails reading:
Error rendering data template: ValueError: Template error: float got invalid input ‘unknown’ when rendering template ‘{{ ((( (states(‘sensor.heavendoor_snmp_wan_in’) | float | round(2)) - (states(‘input_number.inbound_memory’) | float | round(2))) * 8 * 1000) / (15*1000000000)) | float | round(2) }}’ but no default was specified
I think that that snmp sensor is not returning a proper value (or any value at all) and that’s why it considers the input as unkown…
Any help would be greatly appreciated! In fact, if there is a an easier way of getting a traffic history out of dd-wrt feel free to comment!
Thanks!
I’m stuck at the same bit as you. Did you manage to get it resolved?
Unfortunately no.
One thing I’ve noticed is that the dd-wrt counter is 32 bits and placing “version: 2c” might make HA to wait for a 64bit counter… but commenting out the “version: 2c” line did nothing.
I 've also noticed that while at startup, it stops about a minute waiting for snmp…
My plan B was to install ntop (add-on) and make dd-wrt report to it, but it appears that the ntop add-on waits for netflow version 9 and dd-wrt is sending version 5…
So for me atm no internet bandwith counters :frowning:
Hi there! I would like to revisit this.
It seems that the OID is getting bytes sent / received and what we need for a download / upload graphic is speed, no total bytes.
OTOH when I enabled uPnP in DD-WRT, some counterrs appeared as entities, and now I have upload / download counters to monitor through this facility / entities.
Bu there is a problem: this is what I get:
heavendoor_internet_usage
Most spikes are 1h apart.
Any suggestions on how to correct it?
