The Lutron Aurora is the perfect controller for our rental. I’ve used them successfully with the Hue Hub and recently moving to Home Assistant thought they would be easy to use as well.
I am wrong. They are pretty much the most painful thing to get working.
Are there other options for on/off and spin to dim/brighten that “just work” with Home Assistant AND have the nice ability to install over the top of traditional old-school light switches?
How have you configured them? They work mostly okay for me using Zigbee2mqtt. You can bind them directly to a light which is a bit more reliable. I have some directly bound to individual lights, and some using Node-Red
My main issue with the Aurora is how they handle dimming and the fact that if you turn off the light with Home Assistant, you need to press the Aurora’s button twice to turn it back on. That’s an issue with the device itself rather than an issue with Home Assistant. I wrote a more detailed comment about that here:
The Lutron Aurora is the only one I’ve seen, unfortunately. That’s probably why it’s so expensive - no competition that’s quite the same.
I recently decided to ditch the Hue hub and moved all of my Hue lights and accessories to Zigbee2MQTT.
The move was mostly smooth, except the switches.
I decided to install and learn AppDaemon, because it’s a lot easier to write the complex automations to get them to work how I want.
I got them all working, including my two auroras, but those still have problems. I’m planning to replace all of the light switches in the house with z-wave smart switches, but most don’t have a neutral, so I’m stuck with something like the auroras until I can run new cables.
When I get home I’ll dig into it more and try to resolve the issues, or go back to the drawing board. I’d love to write a custom Z2M converter / ZHA quirk, but those may be beyond my skill level. Otherwise, I’m thinking about just using templates or AppDaemon to add an event entity to the device.
With a primarily ZHA home setup, the only reason I’d delve into Zigbee2MQTT now would be for the Aurora’s. I’d make the effort to get up to speed with that, but at this point I feel I should slow down and just study what I’ve been able to get working so far - without a better understanding of what I’ve managed to get working to date.
That is to day, I just wanted to relate my appreciation for your efforts and the update.
