Simple HTTP command, fails
I am trying to make an automation that when triggered, does a wget command for a URL. I tried to do do this all in the configuration.yaml file but since it has a “&” in it fails. In Discord, it was reccomended to me to make a bash script but I cannot seem to get that to work either. I now get an exit code of “2” with the following setup.
The command that I am trying to run:
wget 'http://192.168.1.80/admin?profile=1&lock=1&user=user&pw=pw' -O arm.txt
My configuration.yaml file
shell_command:
  lotbot_motion_arm: sh ./usr/bin/lotbot_motion_arm.sh
My /usr/bin/lotbot_motion_arm.sh file
 #!/bin/bash
# Trigger Blue Iris to Set to Profile 1 and not lock
/usr/bin/wget 'http://192.168.1.80/admin?profile=1&lock=1&user=user&pw=pw' -O arm.txt
From the Log
2018-11-30 17:09:59 ERROR (MainThread) [homeassistant.components.shell_command] Error running command: sh ./usr/bin/lotbot_motion_arm.sh, return code: 2
I can’t find a fault in your syntax at first glance.
As per the man page for wget:
(Return code:)
2
Parse error—for instance, when parsing command-line options, the ‘.wgetrc’ or ‘.netrc’...
Can you just run:
wget http://192.168.1.80/admin?profile=1&lock=1&user=user&pw=pw
and see if that works?
Yes, if I run the command manually it works as expected.
Are you sure that . is supposed to be there? It makes the path relative to the current directory when run. IE if run from /home/homessistant the path will be /home/homeassistant/usr/bin/lotbot_motion_arm.sh. If you really mean /usr/bin/lotbot_motion_arm.sh, lose the leading .
