Hi!
I am noob so my apologies in advance.
I want to create a simple toggle switch, basically to connect sonoff with ewelink with HA via IFTTT. Tasmota YES but not yet So I need synchronization on/off in both ways
All current topics are not up to date or are not comprehensive. According to my knowledge, I need to:
- In configuration/integration add IFTTT where I get info:
IFTTT URL: http://xxxxxxxx.duckdns.org/api/webhook/30xxxxxxxxxxxxxxx Method: POST Content Type: application/json
- Add in IFTTT webhook services
- Get API from IFTTT webhook setting that looks like that, the part after use/ is out API
- Add to configuration.yaml
ifttt:
key: e2xxxxxxxxxxxxxxxxxxx
To that point I had no issues, even I managed to trigger ifttt action.
Next, the tricky part starts. I need to add input_boolean, switch (templet?), actions in Home Assistant + 4 ifttt applets. It would be super nice if somebody help with that. It seems that layout of ifttt applets for ewelink → HA has changed completely. But event than there is different votes about how it should look like http or https, with or without port
input_boolen in config
input_boolean: sonoff_bedroom_2: name: Switch Bedroom II initial: off
automation
- action: - data: event: sonoff_bedroom_2-on service: ifttt.trigger alias: Switch Bedroom II On condition: [] id: 'abc' trigger: - entity_id: input_boolean.sonoff_bedroom_2 from: 'off' platform: state to: 'on' - action: - data: event: sonoff_bedroom_2-off service: ifttt.trigger alias: Switch Bedroom II Off condition: [] id: 'cba' trigger: - entity_id: input_boolean.sonoff_bedroom_2 from: 'on' platform: state to: 'off'
