First published blueprint for me so be gentle. I have wanted to replace my RF garage door keypad for a few years. Came across the Xfinity style (XHK1-UE) keypads and thought it to be a good fit. Obviously they are not IP rated for outdoor use but I have come up with another solution to keep it dry.
I found Stefan’s blueprint for syncing these keypads to an alarm panel definition in HA where he also had a few custom PIN action functions. I did not need the alarm panel sync for my use case so I used his custom PIN code and expanded it to support eight codes.
I have only tested this with Xfinity XHK1-UE but I presume it will work with other similar keypads supported in Z2M.
blueprint:
name: Simple Keypad Code Actions
description: This blueprint simply takes 4 digit codes from zigbee keypads and executes an action. Eight pin/action pairs are defined but this can easily be expanded. Based on original blueprint from AndrejDelany.
domain: automation
input:
z2m_keypad_path:
name: MQTT State Topic of your Zigbee2MQTT Keypad
description: 'The State Topic is composed of your Zigbee2MQTT base_topic (see
your Z2M Addon Configuration) and the Friendly Name of your keypad in Z2M.
Example: zigbee2mqtt/Keypad'
default: zigbee2mqtt/Keypad
custpin1:
name: Custom PIN 1
default: 0
description: 'A custom PIN to trigger a custom action. Example: 0000'
action_cust1:
name: Action Custom 1
description: An action to be performed when custom PIN 1 is entered.
default: []
selector:
action: {}
custpin2:
name: Custom PIN 2
default: []
action_cust2:
name: Action Custom 2
description: An action to be performed when custom PIN 2 is entered.
default: []
selector:
action: {}
custpin3:
name: Custom PIN 3
default: 0
action_cust3:
name: Action Custom 3
description: An action to be performed when custom PIN 3 is entered.
default: []
selector:
action: {}
custpin4:
name: Custom PIN 4
default: []
action_cust4:
name: Action Custom 4
description: An action to be performed when custom PIN 4 is entered.
default: []
selector:
action: {}
custpin5:
name: Custom PIN 5
default: 0
action_cust5:
name: Action Custom 5
description: An action to be performed when custom PIN 5 is entered.
default: []
selector:
action: {}
custpin6:
name: Custom PIN 6
default: []
action_cust6:
name: Action Custom 6
description: An action to be performed when custom PIN 6 is entered.
default: []
selector:
action: {}
custpin7:
default: 0
action_cust7:
name: Action Custom 7
description: An action to be performed when custom PIN 7 is entered.
default: []
selector:
action: {}
custpin8:
name: Custom PIN 8
default: []
action_cust8:
name: Action Custom 8
description: An action to be performed when custom PIN 8 is entered.
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/zigbee2mqtt-sync-keypad-and-with-alarm-control-panel-states/345311
variables:
pin_var_cust1: !input custpin1
pin_var_cust2: !input custpin2
pin_var_cust3: !input custpin3
pin_var_cust4: !input custpin4
pin_var_cust5: !input custpin5
pin_var_cust6: !input custpin6
pin_var_cust7: !input custpin7
pin_var_cust8: !input custpin8
- platform: mqtt
topic: !input z2m_keypad_path
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- choose:
- conditions:
- condition: template
value_template: '{{ trigger.payload_json.action_transaction != null and
trigger.payload_json.action_code == pin_var_cust1 }}'
sequence:
- choose:
default: !input action_cust1
- choose:
- conditions:
trigger.payload_json.action_code == pin_var_cust2 }}'
sequence:
- choose:
default: !input action_cust2
- choose:
- conditions:
trigger.payload_json.action_code == pin_var_cust3 }}'
sequence:
- choose:
default: !input action_cust3
- choose:
- conditions:
trigger.payload_json.action_code == pin_var_cust4 }}'
sequence:
- choose:
default: !input action_cust4
- choose:
- conditions:
trigger.payload_json.action_code == pin_var_cust5 }}'
sequence:
- choose:
default: !input action_cust5
- choose:
- conditions:
trigger.payload_json.action_code == pin_var_cust6 }}'
sequence:
- choose:
default: !input action_cust6
- choose:
- conditions:
trigger.payload_json.action_code == pin_var_cust7 }}'
sequence:
- choose:
default: !input action_cust7
- choose:
- conditions:
trigger.payload_json.action_code == pin_var_cust8 }}'
sequence:
- choose:
default: !input action_cust8
default: []
default: []
mode: restart
