Hi!
I have a simple lamp like the picture below and I want to put a ESP8266 inside to make it connected. I will use a relay to control the 120VAC on the bulb.
I want to keep using the toggle switch but to read its state on a Digital Input, it will have 3.3V on it. Since it’s connected I will be able to toggle the relay from the network but obviously without physically moving the toggle switch to the opposite position… Basically when the toggle value changes, it toggles the bulb state, so there’s no On/Off position on the switch.
Now I am not sure if I can achieve what I want with a basic ESPHome switch component or if I need to implement a custom component with arduino specific code. Also I want to make sure the toggle switch will be functional without Wi-Fi.
The toggle switch will need to be on a different GPIO as the relay so I am wondering how I could use it internally without exposing its state to the network.
This will be my first ESPHome project so I might have very elementary concepts to learn.
I’m sure I can figure out a way to make it work but I don’t want to miss the simpler approach.
Cheers,
