Hi, I’m trying to create a simple light transition to change scenes depending on the time of the day. Does anyone know what I’m doing wrong?
- id: transition_light
alias: “Light transition”
trigger:- platform: time
minutes: ‘/5’
seconds: 00
condition: - condition: state
entity_id: group.lights
state: ‘on’
action: - service: scene.turn_on
data_template:
entity_id: >
{% if (float(as_timestamp(now)) > 18) and (float(as_timestamp(now)) < 19)%} # 6pm ~ 7pm
scene.sunset
{% elif (float(as_timestamp(now)) > 19) and (float(as_timestamp(now)) < 20)%} # 7pm ~ 8pm
scene.feet_up
{% elif (float(as_timestamp(now)) > 20) and (float(as_timestamp(now)) < 21)%} # 8pm ~ 9pm
scene.Laila
{% elif (float(as_timestamp(now)) > 21) and (float(as_timestamp(now)) < 22)%} # 9pm ~ 10pm
scene.Jump
{% elif (float(as_timestamp(now)) > 22) and (float(as_timestamp(now)) < 23)%} # 10pm ~ 11pm
scene.relax
{% elif (float(as_timestamp(now)) > 23) and (float(as_timestamp(now)) < 24)%} # 11pm ~ 12am
scene.bedtime
{% else %}
scene.night_light
{% endif %}
- platform: time
The error I’m seeing in the logs are:
2017-08-20 08:45:00 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 180, in _step
result = coro.send(None)
File “/usr/src/app/homeassistant/components/automation/init.py”, line 343, in async_trigger
yield from self._async_action(self.entity_id, variables)
File “/usr/src/app/homeassistant/components/automation/init.py”, line 433, in action
yield from script_obj.async_run(variables)
File “/usr/src/app/homeassistant/helpers/script.py”, line 151, in async_run
yield from self._async_call_service(action, variables)
File “/usr/src/app/homeassistant/helpers/script.py”, line 181, in _async_call_service
self.hass, action, True, variables, validate_config=False)
File “/usr/src/app/homeassistant/helpers/service.py”, line 74, in async_call_from_config
config[CONF_SERVICE_DATA_TEMPLATE]))
File “/usr/src/app/homeassistant/helpers/service.py”, line 70, in _data_template_creator
for key, item in value.items()}
File “/usr/src/app/homeassistant/helpers/service.py”, line 72, in _data_template_creator
return value.async_render(variables)
File “/usr/src/app/homeassistant/helpers/template.py”, line 101, in async_render
return self._compiled.render(kwargs).strip()
File “/usr/local/lib/python3.6/site-packages/jinja2/asyncsupport.py”, line 76, in render
return original_render(self, *args, **kwargs)
File “/usr/local/lib/python3.6/site-packages/jinja2/environment.py”, line 1008, in render
return self.environment.handle_exception(exc_info, True)
File “/usr/local/lib/python3.6/site-packages/jinja2/environment.py”, line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File “/usr/local/lib/python3.6/site-packages/jinja2/_compat.py”, line 37, in reraise
raise value.with_traceback(tb)
File “”, line 1, in top-level template code
TypeError: ‘>’ not supported between instances of ‘NoneType’ and ‘int’
