I’m quite new with HA and just having trouble with some simple flow where I just don’t find my error.
The problem is, that my flow sometimes works - sometimes not. It’s a light group that turns on with motion sensor and off in the same flow, when no motion was detected for a while. In the log I can see the motion sensor publishes the “not motion action” but the lights just don’t turn off. And sometimes the lights also don’t turn on. It seems to be totally randomly.
There could be any number of reasons including your condition, the fact that its in ‘single’ mode with multiple triggers, you could have reloaded (saved) an automation during the 1 minute ‘duration’ in the trigger causing it not to fire, etc…
You really need to look at the diagnostic data to see what happened.
I try not to use devices at all… but it still should work fine with devices…
Thanks a lot AllHailJ, by coding skills are still to little to understand all of your code yet. I need to learn a little bit more about that before. But still thank you. I will try to rebuild your code with my settings at a point.
Found my problem: Im using the condition with the lux value with the idea the light only turns on when it’s dark. But that condition aborts the turn off moment, because it’s too bright at that moment by the light itself.
You really need a dedicated lux sensor sadly. I tried using the lux in my movement sensors and quite frankly it’s pointless.
They are, at best, not accurate and as you have found don’t always report correctly on movement.
Lux is only reported on movement and not when nothing is going on. So the last time it detected movement it was “bright” and therefore that’s where the lux level will stay. It’s a bit hit and miss. As I say I got around it by having dedicated lux sensors in the rooms where I use this sort of automation.
Personally I always make 2 or more automations on the lights. Triggering on both on and off can lead to strange behavior as in the case, and the code gets much more complicated leading to manual errors.
It looks crowdy in the automation overview, however the overview is not used for anything besides creating the automations.
I was checking my trace and there is everything all right. The automation is turning off the light but in reality sometimes the lights don’t turn off. How can I check where is the problem occuring? In the ZigBee2MQTT protocol?
How would you start an error analysis in this situation when automation seems to work right?
