Simple Local Webpage Scape Help Needed
Really not getting this, need to pull the pressure and temperate from a local webpage device into a sensor. I think I need scrape but I cant get it working.
Here is the local page.
Any help at all would be amazing. I have two of these to setup.
Will
I have this so far
scrape:
But it don’t work :frowning:
Where does select: "p" come from. What does "p" come from?
It was from an example online, I have no idea what I am doing, lol
The device also provides the data via this page, maybe a better way to scrape?
I have now managed to get it to scape, but it pulls in the whole string.
Aqua-Scope Device-Id: 0ea5b1d9Uptime: 416208 sFlowState: 0 Water Cons: 0 mlPressure: 1788 mBarExt Water Sensor: 0Battery Voltage: 600 mVWater Temperature: 346 1/10 C Home Net (JSON) Data (JSON) Setup Config
How do I trim out just the data I need?
Think I need a value template ?
I think so.
Struggling to find a good guide on how to do it.
You mean other than Templating - Home Assistant
Perhaps
"{{value_json.Pressure}}"
Yep, I tried that, and HA just shows state of sensor as unknown.
scrape:
  - resource: http://192.168.5.127
      - name: "Will Test Scrape"
        select: "*"
        value_template: "{{value_json.Pressure}}"
Managed to get it working :slight_smile: Now how to convert the value from mBar to PSI ???
Simple template, plus convert mbar to psi - Google Search
Sorry im still learning, what is a simple template. I understand how to convert myself, but unsure how to get HA to do it. At the moment, my tile displays in mBar. Wanting to convert or Bar first :slight_smile:
scrape:
  - resource: http://192.168.5.127/data
        select: "*"
        value_template: "{{value_json.Pressure | float(0) / 1000}}"
try
value_template: "{{value_json.Pressure | float(0) / 1000 / 68.948 }}"
You may need to add
unit_of_measurement: psi
That works, woo hoo thank you
