Simple Radio Player Dashboard?
I am trying to build a simple radio frontend in a lovelace dashboard to use for my retired father who himself used to be a radio reporter. The emphasis here is on SIMPLE.
I want:
  • Buttons to play predefined Stations (that are all available in Radio Browser)
  • Buttons to toggle the different chromecast-speakers in the house (join / unjoin stream)
  • Buttons to increase / decrease the volume and stop the radio (this seems feasible)
Radio browser has so many stations, it can’t be those cannot be called up by e.g. a button in lovelace? Thats the only useful application of the Radio Browser integration I can think of - yet all solutions I found require complicated YAML and manual research of the stream-url. This cant be true?
Joining / unjoining cast-speakers from whatever is playing is also such an obvious function. Yet I cant find any simple solution to this, it seems like you always have to specify where you wanna play something BEFORE you play it?
Please tell me I’m stupid and there is a simple solution to all this! Any help appreciated.
Take a look at the mini media player card.
https://community.home-assistant.io/t/lovelace-mini-media-player/68459/1970
Thank you - that loooks promising, at least UI-wise. However it still relies on a scripts in the background for each button to call a specific playlist.
Any Idea how i could directly call a radio station? It should be possible since the tiles / functions are all there in the Radio Browser…
The way i do it is I have a simple automation to play a radio station I use on each speaker that is available. so they are easy to copy and change when the online radio station changes its url etc. I then have a helper button to choose radio station and one to choose speaker. These are then setup in an automation using choose as the trigger and calling the automation for the channel. Along with a simple helper button for play and one for stop to trigger the automation’s.
I then use custom:auto entities in a conditional card to display whatever media player is playing.
type: conditional
conditions:
  - condition: state
    entity: media_player.media_players
    state: 'on'
card:
  type: custom:auto-entities
  card:
    type: entities
    state_color: true
  filter:
    include:
      - group: media_player.media_players
        state: playing
    exclude: []
It ends up looking like this wjhen playing
I can upload more code if needed but it is simple enough to create with the UI stuff.
That looks exactly like what i’m trying to accomplish!
Since I used to exclusively automate in Node Red until recently and am only starting out with automations and dashboard building in YAML, I am still quite overwhelmed with all the coding.
I would be most grateful if you could drop some code of your automations and lovelace for me to better understand and learn how to build this.
Thank you so much!
A radio station automation
alias: Shropshire Live HG
description: ""
  - platform: state
    entity_id:
      - input_button.shropshire_live
condition: []
  - data:
      media_content_id: >-
        https://stream-01.aiir.com/iahhslxolv3uv?zt=eyJhbGciOiJIUzI1NiJ9.eyJzdHJlYW0iOiJpYWhoc2x4b2x2M3V2IiwiaG9zdCI6InN0cmVhbS0wMS5haWlyLmNvbSIsInJ0dGwiOjUsImp0aSI6IlBOYURtOU52U1Q2TEQzU3BMOTlPM1EiLCJpYXQiOjE3MjMxODU5NTIsImV4cCI6MTcyMzE4NjAxMn0.OFmlWmQrCTjk4GISjcKNVezgF_b71mihD56vYTzAt1U
      media_content_type: Radio
      entity_id: media_player.home_group
    action: media_player.play_media
  - data:
      volume_level: 0.1
    enabled: false
    action: media_player.volume_set
mode: single
The more complex one for spaekers and stations
alias: Radio Stations and Speaker
description: ""
  - platform: state
    entity_id: input_button.radio_play
condition: []
  - choose:
      - conditions:
          - condition: state
            entity_id: input_select.radio_stations
            state: Radio Wales
        sequence:
          - choose:
              - conditions:
                  - condition: state
                    entity_id: input_select.speakers
                    state: Office Speaker
                sequence:
                  - data: {}
                      entity_id:
                        - automation.wake_up_radio_wales_adrian
                    action: automation.trigger
              - conditions:
                  - condition: state
                    state: Kitchen Speaker
                sequence:
                  - data: {}
                      entity_id: automation.bbc_sounds_wales_kitchen
              - conditions:
                  - condition: state
                    state: Home Group
                sequence:
                  - data: {}
                      entity_id:
                        - automation.play_radio_wales
              - conditions:
                  - condition: state
                    state: wireless
                sequence:
                  - metadata: {}
                      volume_level: 0.02
                      entity_id: media_player.wireless_player
                  - data:
                        http://lstn.lv/bbc.m3u8?station=bbc_radio_wales_fm&bitrate=320000
                      media_content_type: radio
                    enabled: false
                  - metadata: {}
                      media_id: >-
                      entity_id:
                        - media_player.wireless
                    enabled: true
                    action: mass.play_media
            default: []
      - conditions:
          - condition: state
            state: Radio Shropshire
        sequence:
          - choose:
              - conditions:
                  - condition: state
                sequence:
                  - data: {}
                      entity_id: automation.bbc_sounds_shropshire_office
              - conditions:
                  - condition: state
                sequence:
                  - data: {}
                      entity_id: automation.bbc_sounds_shropshire_kitchen
              - conditions:
                  - condition: state
                    state: Home Group
                sequence:
                  - data: {}
              - conditions:
                  - condition: state
                    state: wireless
                sequence:
                  - data: {}
                      entity_id:
                        - automation.shropshire_live_on_wireless
            default: []
      - conditions:
          - condition: state
            state: Radio 2
        sequence:
          - choose:
              - conditions:
                  - condition: state
                sequence:
                  - data: {}
                      entity_id: automation.bbc_sounds_radio_2_office
              - conditions:
                  - condition: state
                sequence:
                  - data: {}
                      entity_id: automation.bbc_sounds_radio_2_kitchen
              - conditions:
                  - condition: state
                    state: Home Group
                sequence:
                  - data: {}
                      entity_id: automation.bbc_sounds_radio_2_hg
            default: []
      - conditions:
          - condition: state
            state: Shropshire Live
        sequence:
          - choose:
              - conditions:
                  - condition: state
                    state: Home Group
                sequence:
                  - data:
                      skip_condition: true
                      entity_id: automation.shropshire_live
              - conditions:
                  - condition: state
                sequence:
                  - data:
                      entity_id: automation.shropshire_live_os
              - conditions:
                  - condition: state
                    state: wireless
                sequence:
                  - metadata: {}
                      volume_level: 0.01
                  - metadata:
                      title: Shropshire Live
                      thumbnail: >-
                        https://www.shropshirelive.com/wp-content/uploads/2018/07/shropshirelive-black-120x120.png
                      media_class: music
                      children_media_class: null
                      navigateIds:
                        - media_content_type: app
                          media_content_id: media-source://radio_browser
                        - media_content_type: music
                          media_content_id: media-source://radio_browser/country/GB
                        media-source://radio_browser/480e9fc1-2392-4a3d-8926-d9fdb10f8ea6
                      media_content_type: audio/mpeg
                    enabled: false
                  - action: automation.trigger
                    metadata: {}
                      entity_id: automation.shropshire_live_on_wireless
                    enabled: false
                    metadata: {}
    default: []
mode: single
And the stop one
alias: Stop Radio
description: ""
  - platform: state
    entity_id: input_button.stop_radio
condition: []
  - data: {}
      entity_id:
        - media_player.home_group
        - media_player.office_speaker_3
        - media_player.kitchen_speaker
        - media_player.office_wireless
        - media_player.fred
        - media_player.wireless_player
    action: media_player.media_stop
mode: single
You will need to change speakers and stations obviously unless you like dodgy local radio from north midlands.
And the code for the whole dash board card
type: grid
cards:
  - type: entities
    entities:
      - entity: input_select.radio_stations
      - entity: input_select.speakers
  - type: tile
    entity: input_button.radio_play
    tap_action:
      action: toggle
  - type: tile
    entity: input_button.stop_radio
    tap_action:
      action: toggle
  - type: conditional
    conditions:
      - condition: state
        state: "on"
    card:
      card:
        type: entities
        state_color: true
      filter:
        include:
            state: playing
        exclude: []
  - type: tile
    entity: input_boolean.llanyblodewel_flood
    icon: ""
    visibility:
      - condition: state
        state: "on"
  - type: tile
    entity: input_boolean.maesbrook_flood
    visibility:
      - condition: state
        state: "on"
  - type: markdown
    content: "{{states('sensor.low_battery_devices')}}"
    title: Low batteries
    visibility:
      - condition: state
        entity: sensor.low_battery_devices
        state_not: unavailable
Try it see how you get on :slight_smile:
Just realised there is other code for that card about flood and batteries.
Here it is properly.
type: grid
cards:
  - type: entities
    entities:
  - type: tile
    tap_action:
      action: toggle
  - type: tile
    tap_action:
      action: toggle
  - type: conditional
    conditions:
      - condition: state
        state: "on"
    card:
      card:
        type: entities
        state_color: true
      filter:
        include:
            state: playing
        exclude: []
Amazing, thank you so much!
I’ll sit down, try to understand it all and adapt it to my needs.
Thank you, sir!
