Simple scenes
Hi I am very new to zigbee I have a simple task that is to operate a radiator system I have installed smart radiator valves and a gateway and a smart switch to bring on the boiler pump so this is how I see it.
If a radiator valve drops below a set temperature THEN it brings on the switch, the question is how does it turn it off when the temperature is reached there doesn’t seem to be an ELSE, currently it just stays on
Post your code for what you have.
You will probably need to do 2 separate automations; one for on, one for off.
