Added “debug option” to see all the error messages
various bugfixes/improvements
Also, there is a hidden feature: clicking in a secret place, you can open the engine log in a modal window, instead of browsing the shared folder. I can’t tell you where, because it is a hidden secret feature
Note: this release has modifications in CSS and JS files, so it could happen that your browser would keep using the cached files. If you see something strange or something missing, just force the reload of the page (CTRL+F5) or empty the cache.
is there a way to set a “retry count”? unfortunately the automatic does not always work. i had to set a higher interval in schedy so that all switches and lights react
This setting tells Schedy how often it should try sending a
value to the actor. If the actor reports the set value back, no
further retry is made. You may find this useful if the connection
between Home Assistant and your actor is unreliable. Set to 0 in
order to disable retrying entirely. send_retries: 10
How many seconds to wait before retrying. send_retry_interval: 30
Somehow the time is wrong. It must have happened with one of the latest releases. It’s always one hour behind. Schedy is at the right time. For example „Sofalampe“ is defined to switch on at 6am. In reality it switches on at 7am.
Hi. i´m really new in HA. Could you please tell me, how i can add SimpleScheduler in homeassistant manually? I´m not using Hass.io. I´ve installed HACS but i coulnd add your repository manually to it.
i added a scedule to turn on my lights. After removing one schedule, it keeps turning on my lights.
so i removed all scheduled (from the UI) but one of the lights is turned on every weekday on 07.00.
where should i look to remove this?
is there a file somewhere that saves a schedule that the UI did not remove??
i’m using a Raspberry PI with Home Assistant Core 0.107.5
UPDATE: The problem is not in the addon. it was my old fault. i forgot i had some scenes running in the original eWelink app off my sonoff switches… sry !!
Hi Arthur,
Thanks for the reply but i have already an automation to handle this situation and i think at moment i’ll keep these setting. do you think It is possible to add the offset into future release?
