Simple script (if then else issue)
I am having issues with a script that has if - then - else structure. Am new to HA, can’t figure out how to correctly program it. Example with if - then - else in the documentation is about automation, not script and I could not understand the correct ~form for the scrip. Please take a look and suggest correct structure. The script has to toggle door lock based on status of binary sensor that shows if the door is locked or not.
thanks!
      togle_front_door:
        alias: "toggle door"
        icon: "mdi:home-lightning-bolt"
        mode: single
        sequence:
        - choose:
          # IF door is closed
            - conditions:
                - condition: state
                  entity_id: binary_sensor.front_door_is_closed
                  state: 'on'
              sequence:
               - service: script.open_front_door
        # ELSE (door is opened)
            default:
            sequence:
                - service: script.close_front_door
solved.
correct code is
    togle_front_door:
      alias: "togle"
      mode: single
      sequence:
          choose:
              conditions:
                  condition: state
                  state: "on"
              sequence:
          default:
