Simple Solar Card
After several iterations of showing all the stats and information to do with my solar and electricity usage and wanting to replace my smart meter with my own mobile phone display, I eventually created this display.
I’m on Octopus flux and force charge between 2a.m and 5a.m, and running the dishwasher in those times too.
Around 5pm (watching “The Chase” and making dinner!), I check the display and figure whether to force discharge to around 60% (checking again when The Chase has finished) which (depending on where in the year we are, currently June), will power the house until 2.a.m.
To avoid solar anxiety I don’t look at the money earnt I just wait for my :moneybag: “win” at the end of every month :slight_smile:
  • The battery percentage
  • If solar is charging the battery (flashing)
  • How long until the battery is charged
  • How much solar power is being generated
  • How much is feeding in (flashing)
  • The yield for the day (not really needed but interesting and I had space)
  • The energy consumption by the house
It’s using the horseshoe card the fiddly bit was figuring the (estimated) time to charge for which I created my own sensor.
 # battery charges to 98% and capacity is 5.8kwh
  - name: solax_battery_predicted_time_to_charge
    unique_id: solax_battery_predicted_time_to_charge
    state: >
      {% set powerLeft = (float(100) - (states('sensor.solax_battery_level') | float )) %}
      {% set batteryPower = (states('sensor.solax_battery_power') | float) %}
      {% if batteryPower > 0 %}
        {% set ratioLeft = powerLeft/batteryPower  %}
        {{ as_timestamp(now() + timedelta(hours=( 0.98 * float(58) * ratioLeft))) | timestamp_custom("%H:%M", True) }}
      {% endif %}
…and the control yaml, in a swipe card if you really do want to see any more info.
There are some extra sensors which are just true/false (like if the battery is charging) to help with setting the animations.
type: custom:swipe-card
start_card: 0
parameters:
  height: 180px
  initialSlide: 1
  centeredSlides: true
  effect: cards
  slideShadows: false
  spaceBetween: 20
  slidesPerView: 1
  loop: false
  preventClicksPropagation: true
  preventClicks: true
cards:
  - type: grid
    cards:
      - type: custom:flex-horseshoe-card
        entities:
          - entity: sensor.solax_battery_level
            decimals: 0
            unit: '%'
            area: Battery
            icon: mdi:battery-60
          - entity: sensor.solax_battery_power
            decimals: 0
            unit: W
            area: Power
            icon: mdi:lightning-bolt-circle
          - entity: sensor.solax_battery_predicted_time_to_charge
            area: est fully charged
          - entity: sensor.solax_is_battery_charging
        show:
          horseshoe_style: lineargradient
        animations:
          entity.3:
            - state: 'true'
              icons:
                - animation_id: 0
                  styles:
                    - color: orange;
                    - animation: flash infinite 3s ease-in-out both;
            - state: 'false'
              icons:
                - animation_id: 0
                  styles:
                    - color: white;
        layout:
          hlines:
            - id: 0
              xpos: 50
              ypos: 40
              length: 70
              styles:
                - opacity: 0.2;
          states:
            - id: 0
              entity_index: 0
              xpos: 45
              ypos: 55
              styles:
                - font-size: 1.5em;
            - id: 1
              entity_index: 1
              xpos: 50
              ypos: 70
              styles:
                - font-size: 1.5em;
            - id: 2
              entity_index: 2
              xpos: 50
              ypos: 100
              styles:
                - font-size: 1em;
          areas:
            - id: 0
              entity_index: 0
              xpos: 50
              ypos: 30
              styles:
                - font-size: 1.5em;
            - id: 1
              entity_index: 2
              xpos: 50
              ypos: 90
              styles:
                - font-size: 0.8em;
          icons:
            - id: 0
              animation_id: 0
              entity_index: 0
              xpos: 35
              ypos: 55
              align: end
            - id: 1
              entity_index: 1
              xpos: 35
              ypos: 70
              align: end
              styles:
                - color: orange;
        horseshoe_scale:
          min: 0
          max: 100
        color_stops:
          '50': rgb(212,175,128)
          '90': orange
        card_mod:
          style: |
            ha-card {
             # border-radius: 50%;
              border:none;
             # background: linear-gradient(to top, rgb(0,0,0) ,rgb(64,64,64));
              height: 240px;
              width: 240px
        entities:
          - entity: sensor.solax_solar_total
            decimals: 0
            unit: W
            area: Solar
            icon: mdi:solar-power-variant
          - entity: sensor.solax_yeild_today
            decimals: 0
            unit: kWh
            area: Yeild
          - entity: sensor.solax_feedinpower
            decimals: 0
            unit: W
            area: Feed In
            icon: mdi:transmission-tower-export
          - entity: sensor.solax_is_exporting
            icon: mdi:home-lightning-bolt
          - entity: sensor.electricity_current_demand
        show:
        animations:
          entity.3:
            - state: 'true'
              icons:
                - animation_id: 0
                  styles:
                    - color: orange;
            - state: 'false'
              icons:
                - animation_id: 0
                  styles:
                    - color: white;
        layout:
          hlines:
            - id: 0
              xpos: 50
              ypos: 45
              length: 80
              styles:
                - opacity: 0.5;
          vlines:
            - id: 0
              xpos: 60
              ypos: 60
              length: 30
              styles:
                - opacity: 0.5;
          states:
            - id: 0
              entity_index: 0
              xpos: 58
              ypos: 38
              styles:
                - font-size: 2em;
            - id: 1
              entity_index: 1
              xpos: 75
              ypos: 70
              styles:
                - font-size: 1.5em;
            - id: 2
              entity_index: 2
              xpos: 30
              ypos: 70
              styles:
                - font-size: 1.5em;
            - id: 3
              entity_index: 4
              xpos: 55
              ypos: 90
              styles:
                - font-size: 1.2em;
          areas:
            - id: 0
              entity_index: 0
              xpos: 50
              ypos: 20
              align: centre
              styles:
                - font-size: 1.5em;
            - id: 1
              entity_index: 1
              xpos: 75
              ypos: 55
              align: centre
              styles:
                - font-size: 1em;
                - opacity: 0.8;
            - id: 2
              entity_index: 2
              animation_id: 0
              xpos: 35
              ypos: 55
              align: centre
              styles:
                - font-size: 1.2em;
                - opacity: 0.8;
          icons:
            - id: 0
              entity_index: 0
              xpos: 35
              ypos: 35
              align: centre
              styles:
                - color: orange;
            - id: 1
              entity_index: 2
              animation_id: 0
              xpos: 58
              ypos: 70
              align: centre
            - id: 2
              entity_index: 3
              xpos: 40
              ypos: 89
              align: centre
              styles:
                - color: orange;
        horseshoe_scale:
          min: 0
          max: 5000
        color_stops:
          '90': orange
        card_mod:
          style: |
            ha-card {
              border:none;
              height: 240px;
              width: 240px
    columns: 2
  - type: custom:power-flow-card
    entities:
      battery: sensor.solax_battery_power
      battery_charge: sensor.solax_battery_level
      grid: sensor.electricity_current_demand
      solar: sensor.solax_solar_total
    inverted_entities: battery
    watt_threshold: 1000
    min_flow_rate: 1.5
    kw_decimals: 2
I’ve been looking for a simple real-time solar graph. I’ll try this out. Thanks for sharing!
I’ve nicked your card and managed to get everything working except the predicted time to charge. copied your yaml, pasted into sensor.yaml and amended with my Fox sensors but it doesn’t show up as a sensor.
