Not 100% sure what you ask for, but yes I think so. It does though have a name override: ReadingLamp.
The names are cut’n paste from automation created in the GUI, so I suppose they are right.
Thanks, that moved me forward. I didn’t see any formatting errors, and all changes I did gave me errors when I did “Check Config” under Configuration->ServerControl.
But after an upgrade and a reboot , the [light.test_example_lamp] showed up in States tab under Developer Tools .
( I think the reboot made a difference ,not the upgrade.)
And I could maneuver it from there. That is a great step forward.
But still, it doesn’t react on automation rule.
Thanks for moving it forward.
Edit:
I do see
“Removing current message” for this node in the z-wave log.
Can you post your latest automation? Also, you can try to manually execute the automation? That way, you will know if your issue lies in the trigger or the action part of the automation.
Edit: you can execute by looking it up in the States page, then open the pop up and click Execute. This will skip the trigger and execute the action.
Scripts are coming, until then, yes I could execute through States. Manually triggering the automations doesn’t work.
Now that also worked , after another reboot…,
No longer 100% sure it didn’t work just prior to reboot.
Edit2: Now the trigger worked! Don’t know why.
Name and alias on automation entry was the same before, and that have been changed,
Thanks all.
