Simple Timer to turn off a light, timer stops when the light is switched off manuallly
A simple timer which turns off a light after x amount of time. When the light is turned off, the timer is stopped so if you turn it back on, there is no running timer which could turn it off immediately.
Works with lights and switches.
Code:
blueprint:
  description: Turn off a light after a certain time unless switched off manually
  domain: automation
  input:
    target_light:
      description: The light to turn off
      selector:
        entity:
          domain:
            - light
            - switch
    light_wait:
      description: Time to leave the light on
      selector:
        duration:
      default:
          hours: 0
          minutes: 5
          seconds: 0
  platform: state
  entity_id: !input target_light
  to: "on"
condition: []
  - wait_for_trigger:
      - platform: state
        to: "off"
    timeout: !input light_wait
    continue_on_timeout: true
  - if:
      - condition: state
        state: "off"
    then:
      - stop: ""
    else:
      - alias: "turn off the light"
        service: homeassistant.turn_off
mode: single
