Simple Toggles to Disable LEDs on RPi under System Hardware Menu
While’s there’s lots of advice out there for installing SSH (which I have done, with a Key) and amending either the config files under sys/class/leds, or accessing mnt/boot/config.txt (either directly or on an SD Card in WIndows), unless there is a security concern about folks wanting to simply turn off the PWR and ACT LEDs (i.e. the Power or Activity on the Ethernet Port), surely it must be possible to put a toggle under the System/Hardware setting to enable and disable these?
While I am able to dig around in the file system, I am sure many do not wish to do this, so for someone who just wants them off or on, please, please, please consider this as a function or Addon. Thank you.
e.g. on a RPi 3 or 4
e.g. on a Rock4 C+
Gen
Home Assistant deliberately removed gpio control ages ago.
Oh; was there a specific reason for that?
Raspberry Pi GPIO's deprecated? start here and enjoy the rabbit holes :slight_smile:
Although when I look at it, this LEDs may not be controlled by GPIOs.
Exactly
Thanks for that. Yes, it appears to just be controlled by a couple of simple software switches in the config.txt file located in /mnt/boot/.
That’s why I say that surely implementing that in HA as a toggle on or off is totally doable (although I don’t personally have that very special set of skills…).
Raspberry Pi 3B
# Turn off Power LED
dtparam=pwr_led_trigger=default-on
dtparam=pwr_led_activelow=off
# Turn off Activity LED
dtparam=act_led_trigger=none
dtparam=act_led_activelow=off
# Turn off Ethernet ACT LED
dtparam=eth_led0=14
# Turn off Ethernet LNK LED
dtparam=eth_led1=14
Raspberry Pi 4B
dtparam=eth_led0=4
dtparam=eth_led1=4
OTOH I understand black nail varnish works well.
:laughing: OK… got me there…but it’s less reversible…
Just an update:
I recently swapped my RPi4B to an SSD from an SD Card, noticed there was no longer a /mnt/boot dir and no config.txt file.
Created both to check and rebooted but both were deleted on reboot.
Would anyone know if they are somewhere else and/or alternative methods to disable the flickering LEDs? (apart from tape, paint etc… :slight_smile: )
thanks
[EDIT] Just remembered I actually asked this question before.
So I put the SSD from my RPi4 into my PC’s USB port, opened it up (my drive was called hassos-boot D:) and right there in the root was config.txt; opened it up found the [RPi4] section, put the above LED commands in there.
Lights out and everyone is home… happy.
