abasel
(Andre)
June 14, 2024, 8:49pm
1
I am wanting a simple Text-To-Speech script that I can link to a button that simply broadcasts “Please call me” to a speaker.
Using the Script wizard, I have created the following:
service: tts.speak
metadata: {}
cache: true
media_player_entity_id: media_player.photo_display
message: Please call me.
When I try run it, I get “Failed to call service script/broadcast_please_call_me. must contain at least one of entity_id, device_id, area_id, floor_id, label_id.”
In the Wizard, non of the targer options appear to have anything linked to them so I can’t add them. This said the “Media player entity” specifies a target so I thought that would not be a problem.
I am guessing that I need to add the target explicitly but as no options appear in the wizard when I try, I am not sure how to.
123
(Taras)
June 14, 2024, 9:01pm
2
That means you don’t have any TTS integration installed.
Either install one or use the tts.google_translate_say service call.
abasel
(Andre)
June 15, 2024, 4:16am
3
But that is what confuses me because I do. I am using a telegram bot integration that calls the TTS service. And this works.
alias: "Telegram: /say"
description: Broadcast message to speakers
use_blueprint:
path: marc-romu/telegram-bot--command__action.yaml
input:
telegram_command: /say
telegram_bot: "@baselmania_bot"
sequence:
- service: scene.create
scene_id: photoframe_savesettings
snapshot_entities:
- media_player.photo_display
enabled: true
- service: media_player.volume_set
volume_level: 1
device_id: cxxxxxxxxxxxxxxxxxxx2
- service: tts.google_translate_say
message: "{{ telegram_args_as_text }} "
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- service: scene.turn_on
data: {}
entity_id: scene.photoframe_savesettings
enabled: true
abasel
(Andre)
June 15, 2024, 4:20am
4
Just realised that the telegram bot uses gogle translate and I was using google say.
Think that I am sorted now.
