I need a speaker so I can play tts messages. The speaker doesn’t have to have a particularly good sound, but it should be easy to integrate into home assistant. Maybe one of you knows what the solution would be.
To play audio you will need to have the VLC plugin installed at least, I have that and the spotify plugin’s installed for my uses.
The VLC plugin allows me to play my doorbell chime file saved to the media folder (you can use files via network share if you have that setup in the share settings of your HA install).
Keep in mind if you want to have the same audio file play on your phone or other device you need to have that file on said device and call the channel it will be tied to at the time in the companion app in the automation. i.e
