Simple Way of Adding Multiple Entities to an Area?
Hi there,
I am currently adding areas to my HA instance.
On the area configuration page I can not add any entities/ devices.
I have to go to entities and add a single entity to an area.
When selecting mutliple entities I am not able to add them to an area.
So I really have to add every entity one by one to an area?
Thanks!
/KNEBB
The Spook integration can do it:
action: homeassistant.add_entity_to_area
  area_id: kitchen
  entity_id:
    - light.kitchen_1
    - light.counter_lights
    - light.hallway_1
    - light.hallway_2
    - light.hallway_3
Ok, got a step forward.
I guess I can use some sort of template to match the entities, right?
So what do I put into the entity_id field?
- sensor.wetter_{{ * }}
Or how is the correct syntax?
/KNEBB
Tried now with the following:
  aread_id: wetterdaten
  entity_id:
    - sensor.wetter*
And ran it manually. Got some errors in the trace:
Fehler: extra keys not allowed @ data['aread_id']
Ergebnis:
params:
  domain: homeassistant
  service: add_entity_to_area
  service_data:
    entity_id:
      - sensor.wetter*
  target: {}
running_script: false
Any idea what I did wrong?
/KNEBB
You need to install the Spook integration from HACS… You don’t even seem to have clicked on the link. :laughing:
It is installed - for sure!
It has already alarmed me about some minor glitches:
grafik
You have a typo. It’s area_id, not aread_id
I was trying to add multiple entities to an area:
   area_id: stringa_a
   entity_id:
     - sensor.tigo_a*
But I receive an error:
Unable to execute the action:
Homeassistant.add_entity_to_area
Unknown error
How it is supposed to bulky add entities to an area? Maybe using a template to enumerate the entities, or by adding the entities to a label?
First, did you install the Spook integration linked above?
Yes, you need to either list the entities manually or use a template to create the list. Wildcards like sensor.tigo_a* are not supported.
Yes, spook integration is installed. I’ll try to create a template then.
thanks
