Hi
here is another beginner’s question and let me admit straight away: the simpleness and usefulness of what I am looking for makes me suspect I am just not looking in the right places. So this is probably just a question of pointing the newbie into the right direction.
Rather than setting the value of an entity to a specific number I want to change the value of an entity by an amount.
Here is the use case: whenever sensor.solax_grid_import approaches the contracted limit of say 4.2KW while the inverter charges the battery from the grid I want to decrease number.solax_battery_charge_max_current by 1A and repeat until I get back into a safe range before tripping the mains. And go back up when there is enough buffer. The number function accepts any absolute value from 0-30A but no relative ones.
I have found the template in the dev tools or thought about creating a helper, but it seems rather longwinded.
Thanks in advance for enlightening me.
Alex
Since that’s a number
there’s only the number.set_value
action: https://www.home-assistant.io/integrations/number#actions
That means that templates are the only way to do this.
actions:
- action: number.set_value
entity_id: number.whale_height
value: >-
{{ states('number.whale_height')|float(0) - 1 }}
That’s the way it will be then. Thanks a lot!
