Hello.
Im a total newbie in the HA world. My HA works fine with my z-wave switches and sensors.
But now I would like to configure som magic!
My use case is a button (Fibaro button) that I would like to use in order to turn lights on / off.
But dear! I the world of declarative yaml files, my Google skill leaves much to be wanted.
Can anybody point me to som nice examples, guide och blog or anything usefull?
Please please
I don’t have exactly what you want in my setup but I have something similar which you could use as an example or starting point. I use a split config so the following is in an ‘automations’ directory.
doorbell_light_control.yaml
alias: Doorbell Light Control
initial_state: 'on'
- platform: event
event_type: click
event_data:
entity_id: binary_sensor.switch_158d00018b3ede
click_type: long_click_press
condition:
condition: or
conditions:
- condition: sun
after: sunset
after_offset: '00:00:00'
- condition: sun
before: sunrise
before_offset: '00:00:00'
- service: homeassistant.turn_on
entity_id: light.front_door_light
- delay: '00:01:00'
- service: homeassistant.turn_off
The above will turn on a light if the doorbell button is held for a second, then turn it off after 1 minute. You could remove the automated ‘off’ and change the trigger to a general state change for the Fibaro button however that device operates (might be a single click). Using a condition to check if the light is already ‘on’, you should be able to make it turn ‘off’ with a second click. There was this thread I read on here a week or so ago that had code for doing something similar although its a bit more complex because he is doing dimming as well.
Super tnx
Ill try it first thing tomorrow.
