My HA journey in brief and background:
I discovered HA through ESPHome when trying to use an ESP to automate a simple(-ish) controller for an external wood boiler. This ultimately led to the first installation of HA in a Dock on my desktop (Linux Mint). While useful for playing around with it, I would prefer to have an independant server for HA so I shopped around and got my hands on a cheap (Chinese I think) Intel PC, the Z83-V (or Z83-5). This seems to be a fairly standard box using an Intel Atom and a broadcom chip which provides wifi and BT. I installed Debian onto it and set-up HA Supervised. Debian required a little fettling to get the Broadcom chip working as the firmware blobs were not installed as standard, but once set-up it worked fine and allowed me to remove one of my ESPHome projects which was an interface to 2 Xiaomi wireless thermometers that transmit over BLE. But I don’t have time in my life to manage the upkeep of the underlying Debian installation and the Supervisor kept dropping permission which meant I couldn’t update HA or the add-ons.
So two days ago I laboriously installed HAOS onto the Z83 to replace Debian. Which went relatively smoothly. The backup was restored and everything worked… except for the Bluetooth and Wifi. I’ve enabled the SSH debugging on 22222, so I can see the problem and the solution is (probably) to create another softlink to the firmware file corresponding to the system name reported by the brcmfmac module, but the base filesystem is mounted ro.
All of which leads to my question: Is there a way to modify the filesystem while the system is live, or do I have to modify the HAOS image itself and rewrite it? If so, the testing cycle for this is going to be extremely long.
Thanks in advance,
Jon
