Goal
In my ideal world, HA would implement a RBAC (as per WTH2 - WTH!? No RBAC - Role Based Access Control? (Users & Groups rights)).
My goal was to provide custom access to specific users, so that they could control a limited set of entities for a limited period of time.
Idea
Given that HA includes some low level policies management (ref: Permissions | Home Assistant Developer Docs ), the idea is to create template entities for my special limited users and to enable/disable them considering a validity time period.
Scenario
My house has been 100% homeassistanted
The usual: sensors, automations, buttons, helpers…
And - relevant for this thread - every entry point can be managed by Home Assistant:
- Garage door
- Entrance gate
- Main door lock (Nuki)
- Alarm system (included in HA thanks to an ESP32 wired to the I/Os available, so that I can control it completely)
From time to time, I would like to grant access to my house to my dad, my wife’s mother, or the nanny.
Granting them full access to HA is not an option… you know: with a great power comes a great responsability!
How to (a.k.a. How I do)
Step 1: user and helpers
Create a user, let’s call it LUser via HA interface.
Create start and end input datetime (actually, when the LUser can access your HA):
limitedpermission_luser_start:
name: LP LUser Inizio
has_date: true
has_time: true
limitedpermission_luser_end:
name: LP LUser Fine
has_date: true
has_time: true
Create an input boolean (the current status):
limitedpermission_luser_isvalid:
Create an automation to manage the entities above:
- alias: Limited permissions update isvalid
- platform: time_pattern
seconds: 10
- platform: state
entity_id: input_datetime.limitedpermission_luser_start
- platform: state
entity_id: input_datetime.limitedpermission_luser_end
- if:
- condition: template
value_template: >
{{ state_attr('input_datetime.limitedpermission_luser_start', 'timestamp') < now().timestamp()
and now().timestamp() < state_attr('input_datetime.limitedpermission_luser_end', 'timestamp')}}
then:
entity_id: input_boolean.limitedpermission_luser_isvalid
else:
- service: input_boolean.turn_off
Step 3: Create the “limited” entities
Add a template alarm control panel for LUser:
panels:
limitedpermission_luser_alarmcontrolpanel:
value_template: >
{% if is_state("input_boolean.limitedpermission_luser_isvalid", "off") -%}
unavailable
{%- elif is_state("alarm_control_panel.allarme_casina", "pending") -%}
pending
{%- elif is_state("binary_sensor.state_is_alarm_armed", "on") -%}
armed_away
{%- elif is_state("binary_sensor.state_is_alarm_armed", "off") -%}
disarmed
{%- else -%}
pending
{%- endif %}
arm_away:
event: limitedpermission_event
event_data:
type: alarm_control
username: "luser"
disarm:
- event: limitedpermission_event
event_data:
type: alarm_control
username: "luser"
code: "{{code|string()}}"
value_template: '{{ (code|string()) == "1234" }}'
event_data:
type: alarm_control
username: "luser"
Please note:
- the LUser code for the alarm system is set here
- if the LUser is not in a valid time period, the alarm system status is unavailable
- I am only interested in arm_away and disarm, you can always managed the missing states
Now create two locks, one for the entrance gate, one for the main door:
unique_id: limitedpermission_luser_entrancegate
value_template: >
unavailable
{%- else -%}
{{ is_state('binary_sensor.aqara_contact_entrancegate', 'off') }}
{%- endif %}
unlock:
event_data:
type: entrance_gate
username: "luser"
lock:
event_data:
type: entrance_gate
username: "luser"
unique_id: limitedpermission_luser_kitchendoor
value_template: >
unavailable
{%- else -%}
{{ states('lock.nuki_porta_casina_lock') }}
{%- endif %}
unlock:
event_data:
type: kitchen_door
username: "luser"
lock:
event_data:
type: kitchen_door
username: "luser"
Step 4: LUser commands
Commands and action for the LUser’s entities are sent via events.
Events are managed by the following automation:
- alias: Limited permissions event catchall
mode: queued
- platform: event
event_type: "limitedpermission_event"
condition:
or:
- and:
value_template: "{{ trigger.event.data.username == 'luser' }}"
- condition: state
state: "on"
- choose:
- conditions:
value_template: "{{ trigger.event.data.type == 'alarm_control' and trigger.event.data.name == 'arm_away' }}"
sequence:
- service: script.turn_on
entity_id: script.allarme_casina_arm_away
- conditions:
value_template: "{{ trigger.event.data.type == 'alarm_control' and trigger.event.data.name == 'disarm' }}"
sequence:
entity_id: script.allarme_casina_disarm
- conditions:
value_template: "{{ trigger.event.data.type == 'entrance_gate' and trigger.event.data.name == 'unlock' }}"
sequence:
- service: script.entrance_gate_please_open
caller: "limitedpermissions automation"
- conditions:
value_template: "{{ trigger.event.data.type == 'kitchen_door' and trigger.event.data.name == 'lock' }}"
sequence:
entity_id: script.nuki_please_lock
- conditions:
value_template: "{{ trigger.event.data.type == 'kitchen_door' and trigger.event.data.name == 'unlock' }}"
sequence:
entity_id: script.nuki_please_unlock
Step 5: permissions
Edit the file .storage/auth to give LUser permissions only on the created entities.
First, look for the LUser record, and change group_ids to a special custom group (“limitedpermissions-luser” in this example):
"id": "bd2233e4b2f04f328107ccdf6ff584e6",
"group_ids": [
"limitedpermissions-luser"
"is_owner": false,
"is_active": true,
"name": "luser",
"system_generated": false,
"local_only": false
Then, edit this group to include only the required entities:
"id": "limitedpermissions-luser",
"name": "limitedpermissions luser",
"policy": {
"entities": {
"entity_ids": {
"input_datetime.limitedpermission_luser_end": {
"read": true
"input_datetime.limitedpermission_luser_start": {
"read": true
"input_boolean.limitedpermission_luser_isvalid": {
"read": true
"alarm_control_panel.limitedpermission_luser_alarmcontrolpanel": true,
"input_text.debug_output": true,
"lock.cancello_di_ingresso_luser": true,
"lock.porta_di_ingresso_luser": true
Finally, create a dashboard specific for your LUser:
title: Casina
- theme: Backend-selected
title: Luser
path: luser
badges: []
cards:
- type: conditional
conditions:
- entity: input_boolean.limitedpermission_luser_isvalid
state: 'off'
card:
type: vertical-stack
cards:
- type: custom:mushroom-entity-card
layout: vertical
primary_info: name
secondary_info: none
icon: mdi:account-alert
icon_color: red
- type: conditional
conditions:
state: 'on'
card:
cards:
layout: vertical
primary_info: name
icon: mdi:account-check
icon_color: green
- type: horizontal-stack
cards:
- type: custom:mushroom-lock-card
entity: lock.cancello_di_ingresso_luser
icon: mdi:gate-alert
hold_action:
action: toggle
double_tap_action:
action: none
name: Cancello di ingresso
tap_action:
action: none
layout: vertical
entity: lock.porta_di_ingresso_luser
icon: mdi:door-closed-lock
hold_action:
action: toggle
double_tap_action:
action: none
layout: vertical
name: Porta di ingresso
tap_action:
action: none
- type: alarm-panel
states:
- arm_away
entity: alarm_control_panel.limitedpermission_luser_alarmcontrolpanel
When the user is disabled (i.e.: the current time is not included in the validity time period for this user), the user will get a simple “access expired” message:
When the user is active, he get a simplified yet functional dashboard:
Possible enhancements
Calendar automation
You can use the calendar integration to give the LUser access creating an appointament with some reasonable title/property.
This is the automation I use to handle the nanny user, and granting access 20 minutes before the appointment:
- alias: Calendar Casine - Betty
mode: queued
- platform: calendar
event: start
entity_id: calendar.casine
offset: -00:20:00
event: end
condition:
value_template: "{{ 'Betty' in trigger.calendar_event.summary }}"
- if:
- "{{ trigger.event == 'start' }}"
then:
- service: input_text.set_value
entity_id: input_text.debug_output
value: "Calendar Casine - Betty start: {{trigger.calendar_event.summary}} from {{trigger.calendar_event.start}} to {{trigger.calendar_event.end}}"
- service: input_datetime.set_datetime
entity_id: "input_datetime.limitedpermission_tata_elisabetta_start"
timestamp: "{{ now().timestamp() }}"
entity_id: "input_datetime.limitedpermission_tata_elisabetta_end"
timestamp: "{{ as_timestamp(trigger.calendar_event.end) + (60 * 15)}}"
else:
value: "Calendar Casine - Betty end: {{trigger.calendar_event.summary}} from {{trigger.calendar_event.start}} to {{trigger.calendar_event.end}}"
Telegram “very simplified” board
Just an idea, not implemented that yet. But moving the interaction from HA dashboard to a telegram bot, could make the required access to a specific dashboard… useless.
PROs and CONs
pros!
- It’s a bit of a mess, but it works just fine!
- 100% HA, no external service required
- Every LUser has its own code for alarm unlock
cons
- lots of copy-paste to add a new LUser
- (actually the worst, in my hopinion) you have to set the created dashboard as default on your user app/website, otherwise it goes to the default one where you see the real entities… all broken
- as soon as HA implements some real RBAC, all this will become useless in no time
Conclusion
I have used this approach in my scenario and solved one of my biggest problem.
While this way is quite tricky, seems to be flexible and safe enough… until some real solution will be available in HA.
I hope this help someone!
Please feel free to report any error/missing part, I will try my best to fix them asap
