So that removed the OZW reference from frontdoor_lock_manager_common.yaml but it’s still behaving the same. Services not working and, of course, Lovelace not responding.
I’m still unclear, in my case, which sensor I should be pointing the package to for the access control sensor as I have both:
That’s toggled. I’ve checked everything else I can think of. Also, deleted the custom-component and package and tried the HACS install from scratch. Same error in the logs:
2020-09-02 19:10:34 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template frontdoor Status Report: str: Invalid domain name 'UC'
I’ve triple checked that line in frontdoor_lock_manager_common.yaml.
Curious to hear if this has come up for anyone else.
I’m actually getting that error in my logs as well, but both my front and back door locks seem to be working I’m using OZW though.
EDIT: Scratch that, setting user names / pin codes for my locks are working. Status notifications are not and have never been working afaik. Both sensor.frontdoor_statusreport and sensor.backdoor_statusreport are listed as “unavailable” in entities.
Mine was one of the disabled entities that I had to physically enable when I first included the lock. It shows enabled, but the statusreport sensor is still listed as unavailable in entities.
Your sensor name doesn’t match what you posted in this post append _frontdoor to the sensor name and it should work or reconfigure the integration and re-select your sensor.
