KeyMaster Z-Wave lock manager and scheduler
dude that worked! At least it installed, haven’t fiddled yet, but adding gawk as you just said (apk add gawk) through the terminal and then running ./setup worked! I will report back if I end up being wrong cause I cannot fiddle with it until later.
Hi All,
Can someone please tell me if the following looks correct from my config yaml:
# LOCK MANAGER CONFIGS
binary_sensor:
    sensors:
      allow_automation:
        friendly_name: "Allow Automation"
        value_template: "{{ is_state('input_boolean.allow_automation_execution', 'on') }}"
      system_ready:
        friendly_name: "System ready"
        value_template: "{{ is_state('input_boolean.system_ready', 'on') }}"
        device_class: moving
input_boolean:
  allow_automation_execution:
    name: 'Allow Automation'
    initial: off
  system_ready:
    initial: off
Seems to be something off here.
code looks ok to me.
Wondering if someone can help me here…
I am getting several errors in my logs in relation to adding/updating/clearing user codes.
“Error while executing automation automation.outsidegaragedoor_clear_code. Invalid data for call_service at pos 1: expected int for dictionary value @ data[‘code_slot’]”
Error while executing automation automation.outsidegaragedoor_add_code. Invalid data for call_service at pos 1: expected int for dictionary value @ data[‘code_slot’]
am i missing something?
code for adding was set by setup.sh:
    - alias: OutsideGarageDoor Add Code
        - condition: state
          entity_id: 'binary_sensor.allow_automation'
          state: 'on'
        entity_id: binary_sensor.active_outsidegaragedoor_1, binary_sensor.active_outsidegaragedoor_2, binary_sensor.active_outsidegaragedoor_3, binary_sensor.active_outsidegaragedoor_4, binary_sensor.active_outsidegaragedoor_5, binary_sensor.active_outsidegaragedoor_6
        platform: state
        to: 'on'
        - service: lock.set_usercode
          data_template:
            node_id: >-
                {{states.lock.schlage_be469nxcen_touchscreen_deadbolt_locked_outsidegaragedoor.attributes.node_id}}
            code_slot: >-
                {% set object_id = trigger.to_state.object_id %}
                {% set index = 17 %}
                {% set code_slot = object_id[index:] %}
                {{ code_slot  }}
            usercode: >-
                {% set codetext = 'outsidegaragedoor_pin_' + code_slot | string %}
                {% set code = states['input_text'][codetext].state %}
                {{ code | string }}
    - alias: OutsideGarageDoor Update Code
        entity_id: input_text.outsidegaragedoor_pin_1, input_text.outsidegaragedoor_pin_2, input_text.outsidegaragedoor_pin_3, input_text.outsidegaragedoor_pin_4, input_text.outsidegaragedoor_pin_5, input_text.outsidegaragedoor_pin_6
        platform: state
        - condition: state
          state: 'on'
        - condition: template
          value_template: >-
            {% set index = 14 %}
            {% set b = 'input_boolean.enabled_outsidegaragedoor_' + code_slot | string %}
            {{ is_state(b, 'on') and (trigger.from_state.state != trigger.to_state.state)}}
        - service: persistent_notification.create
          data_template:
            title: "outsidegaragedoor LOCK MANAGER"
            message: >-
              {{ 'You changed the PIN for code  ' + code_slot | string + '. Please enable it in order to make it active.'}}
          data_template:
            entity_id: >-
              {{ 'input_boolean.enabled_outsidegaragedoor_' + code_slot | string }}
I am unfortunately getting a similar error. Everything seems to work fine with my front door lock if I remove the single quotes from input_boolean.allow_automation_execution and input_boolean.allow_automation_execution in my scripts.yaml:
# LOCK MANAGER SCRIPTS
system_cleanup:
    #- service: homekit.start If you use homekit, uncomment this statement
      entity_id: input_boolean.system_ready
        entity_id: input_boolean.allow_automation_execution
customstartup:
However, my second (garage) lock is not functioning properly. I am getting the following errors in log:
Error while executing automation automation.garagesd_clear_code. Invalid data for call_service at pos 1: expected int for dictionary value @ data['code_slot']
AND
Error rendering data template: str: Invalid entity ID 'input_text.garagesd_pin_'
If I run ‘lock.set_usercode’ from services tab with the following data:
node_id: 12
code_slot: 1
usercode: 1234
It seems to work. Obviously doesn’t change the code in lovelace but if I check through the zwave panel I can see the code has changed.
I removed the ’ ’ from those entity_id: sections and my errors went away, but none of the functionality is still working. I did notice some more of the ’ ’ in the _lock_manager_common.yaml file so you may want to check there and see if that resolves the issues for your other door locks.
I tried to run the ‘lock.set_usercode’ from the services tab and the ‘lock.get_usercode’ but they don’t work for me so i’m thinking there is something else that i’m missing also.
I used to use the code from here https://community.home-assistant.io/t/zwave-lock-manager/79252 and that was working.
Yeah, I think my removing those actually did nothing… I found some better ways to debug and found it was a false positive. Anyhow, hate to say the obvious, but you’ve checked your entity ID naming, right?
I am unable to run ./setup.sh
I get…
“bad interpreter: No such file or directory”
Any ideas? Thanks.
where are you trying to run it?
yeah i checked them over several times and no luck
Not sure what you mean. Ubuntu terminal I guess?
have you tried to install gawk? mentioned here:
Yes I saw that comment before and installed gawk via the apt install method.
I’ve been testing the code by adding notifications right after the trigger happens and I get the initial notification (Code Created step 1). However, I am not getting the notification that it’s finished (Code Created Done) after the service: lock.set_usercode section
        - condition: state
          entity_id: binary_sensor.allow_automation
          state: 'on'
        platform: state
        to: 'on'
          data_template:
            title: "debug"
            message: "Code Created step 1"
          data_template:
            node_id: >-
            code_slot: >-
                {{ code_slot  }}
            usercode: >-
                {{ code | string }}
          data_template:
            title: "debug"
            message: "Code Created Done"
Forgot to ask, any errors in your log when running lock.set_usercode from your developer panel?
Not showing any errors when i use the developer panel.
That is super strange. Can you ensure that node_id is active and the default user codes are associated with it?
when i try to run the unlock using developer panel or even from Lovelace lock/unlock, the door locks and unlocks and it says unlocked from RF or something in that nature.
Have you verified you are using the correct node_id when calling the service from dev panel?
yes and i made sure the lock node id matches with the zwave one.
