I did, but I’ve had some issues with it. Right now I’m reconsidering my flows with some new plugins. Here’s what I have but I’m not sure I’d recommend it:
[{"id":"69f4d73ca4b84b08","type":"subflow","name":"Lights w/ Override","info":"","category":"","in":[{"x":60,"y":160,"wires":[{"id":"ed305a652c4e8f78"}]}],"out":[],"env":[],"meta":{},"color":"#DDAA99","status":{"x":2040,"y":80,"wires":[{"id":"83383811b5ed4df3","port":0},{"id":"0fee8606c3952e6f","port":0},{"id":"c5c6766bdf56cf45","port":0}]}},{"id":"20468b3b945fa5b6","type":"change","z":"69f4d73ca4b84b08","name":"Cancel Delay","rules":[{"t":"set","p":"delay","pt":"msg","to":"stop","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":80,"wires":[["8f96fa1b058e3783"]]},{"id":"7896adf9c94c5528","type":"api-call-service","z":"69f4d73ca4b84b08","name":"Light Off","server":"c11bb00b.50dfb","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["{{flow.lightname}}"],"data":"{\"transition\":msg.lighttrans}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1040,"y":220,"wires":[["2f439d85c335e4a4"]]},{"id":"8f96fa1b058e3783","type":"stoptimer-varidelay","z":"69f4d73ca4b84b08","duration":"120","durationType":"num","units":"Second","payloadtype":"num","payloadval":"0","name":"","reporting":"every_second","persist":false,"ignoretimerpass":false,"x":700,"y":220,"wires":[["fd90acfd32576d83"],[],["44de5d91cf4b9ff4"]]},{"id":"44de5d91cf4b9ff4","type":"api-call-service","z":"69f4d73ca4b84b08","name":"Timer Display","server":"c11bb00b.50dfb","version":5,"debugenabled":false,"domain":"input_text","service":"set_value","areaId":[],"deviceId":[],"entityId":["input_text.time_remains"],"data":"{\"value\":msg.payload}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":840,"y":280,"wires":[[]]},{"id":"79a86dfdb1793718","type":"api-current-state","z":"69f4d73ca4b84b08","name":"get Override","server":"c11bb00b.50dfb","version":3,"outputs":2,"halt_if":"true","halt_if_type":"bool","halt_if_compare":"is","entity_id":"{{flow.override}}","state_type":"habool","blockInputOverrides":false,"outputProperties":[],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":470,"y":220,"wires":[[],["8f96fa1b058e3783"]]},{"id":"f46e53a8a6a0248a","type":"api-call-service","z":"69f4d73ca4b84b08","name":"Timer Name","server":"c11bb00b.50dfb","version":5,"debugenabled":false,"domain":"input_text","service":"set_value","areaId":[],"deviceId":[],"entityId":["input_text.time_sensor"],"data":"{\"value\":msg.topic}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":940,"y":80,"wires":[["c38c44acad00dd87"]]},{"id":"d89b11a80e29ad41","type":"function","z":"69f4d73ca4b84b08","name":"","func":"flow.sensorid=flow.get('msg.entity_id');\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":790,"y":80,"wires":[["f46e53a8a6a0248a"]]},{"id":"2f439d85c335e4a4","type":"delay","z":"69f4d73ca4b84b08","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1200,"y":220,"wires":[["83383811b5ed4df3"]]},{"id":"83383811b5ed4df3","type":"api-call-service","z":"69f4d73ca4b84b08","name":"Light Off","server":"c11bb00b.50dfb","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["{{flow.lightname}}"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1360,"y":220,"wires":[["0501096fa77bd1d8"]]},{"id":"0501096fa77bd1d8","type":"change","z":"69f4d73ca4b84b08","name":"Reset Flow","rules":[{"t":"set","p":"lightname","pt":"flow","to":"","tot":"str"},{"t":"set","p":"override","pt":"flow","to":"","tot":"str"},{"t":"set","p":"lightname","pt":"global","to":"","tot":"str"},{"t":"set","p":"override","pt":"global","to":"","tot":"str"},{"t":"set","p":"delay","pt":"msg","to":"","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"","tot":"str"},{"t":"set","p":"override","pt":"msg","to":"override","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":1510,"y":220,"wires":[[]]},{"id":"fd90acfd32576d83","type":"api-current-state","z":"69f4d73ca4b84b08","name":"get Override","server":"c11bb00b.50dfb","version":3,"outputs":2,"halt_if":"true","halt_if_type":"bool","halt_if_compare":"is","entity_id":"{{flow.override}}","state_type":"habool","blockInputOverrides":false,"outputProperties":[],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":880,"y":220,"wires":[[],["7896adf9c94c5528"]]},{"id":"60cc36186d667389","type":"switch","z":"69f4d73ca4b84b08","name":"Motion On or Off?","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"},{"t":"null"}],"checkall":"true","repair":false,"outputs":3,"x":400,"y":160,"wires":[["20468b3b945fa5b6","d89b11a80e29ad41","c5c6766bdf56cf45"],["79a86dfdb1793718","d89b11a80e29ad41"],[]]},{"id":"ed305a652c4e8f78","type":"change","z":"69f4d73ca4b84b08","name":"","rules":[{"t":"set","p":"lightname","pt":"flow","to":"lightname","tot":"global"},{"t":"set","p":"override","pt":"flow","to":"override","tot":"global"},{"t":"set","p":"units","pt":"msg","to":"seconds","tot":"global"},{"t":"set","p":"override","pt":"msg","to":"override","tot":"flow"},{"t":"set","p":"override2","pt":"msg","to":"override2","tot":"flow"},{"t":"set","p":"lightname","pt":"msg","to":"lightname","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":200,"y":160,"wires":[["60cc36186d667389"]]},{"id":"c38c44acad00dd87","type":"api-call-service","z":"69f4d73ca4b84b08","name":"Override Display","server":"c11bb00b.50dfb","version":5,"debugenabled":false,"domain":"input_text","service":"set_value","areaId":[],"deviceId":[],"entityId":["input_text.override"],"data":"{\"value\":msg.override}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"all","x":1220,"y":80,"wires":[[]]},{"id":"591cde0efb2be778","type":"api-current-state","z":"69f4d73ca4b84b08","name":"get Brightness","server":"c11bb00b.50dfb","version":3,"outputs":1,"halt_if":"","halt_if_type":"num","halt_if_compare":"gt","entity_id":"input_number.light_level","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"lightbright","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":950,"y":160,"wires":[["8e976806785ac991"]]},{"id":"8e976806785ac991","type":"api-current-state","z":"69f4d73ca4b84b08","name":"get Delay","server":"c11bb00b.50dfb","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_number.light_delay","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"delay","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1120,"y":160,"wires":[["1be8da90d7ebbfcd"]]},{"id":"2d4b7d3ee2ee6c85","type":"api-current-state","z":"69f4d73ca4b84b08","name":"get Temp","server":"c11bb00b.50dfb","version":3,"outputs":1,"halt_if":"","halt_if_type":"num","halt_if_compare":"gt","entity_id":"input_number.color_temp","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"lighttemp","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":790,"y":160,"wires":[["591cde0efb2be778"]]},{"id":"0fee8606c3952e6f","type":"api-call-service","z":"69f4d73ca4b84b08","name":"Light On Kelvin","server":"c11bb00b.50dfb","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["{{flow.lightname}}"],"data":"{\"kelvin\":msg.colortemp, \"brightness\":msg.lightbright, \"transition\":msg.lighttrans}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1600,"y":160,"wires":[[]]},{"id":"1be8da90d7ebbfcd","type":"api-current-state","z":"69f4d73ca4b84b08","name":"get Color","server":"c11bb00b.50dfb","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.light_color","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"lightcolor","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1280,"y":160,"wires":[["5831b9ec32b1b5e8"]]},{"id":"5831b9ec32b1b5e8","type":"api-current-state","z":"69f4d73ca4b84b08","name":"Get K","server":"c11bb00b.50dfb","version":3,"outputs":1,"halt_if":"","halt_if_type":"num","halt_if_compare":"is","entity_id":"input_number.color_temp","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"colortemp","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1430,"y":160,"wires":[["0fee8606c3952e6f"]]},{"id":"15c633832eaf4e8d","type":"api-call-service","z":"69f4d73ca4b84b08","name":"Light On no kelvin","server":"c11bb00b.50dfb","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["{{flow.lightname}}"],"data":"{\"color_name\":msg.lightcolor, \"brightness\":msg.lightbright, \"transition\":msg.lighttrans}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1530,"y":100,"wires":[[]]},{"id":"c5c6766bdf56cf45","type":"api-call-service","z":"69f4d73ca4b84b08","name":"Light On Adaptive","server":"c11bb00b.50dfb","version":5,"debugenabled":true,"domain":"adaptive_lighting","service":"apply","areaId":[],"deviceId":[],"entityId":["switch.adaptive_lighting_adapt_color_lr_adaptive"],"data":"{\"lights\":msg.lightname, \"turn_on_lights\":true, \"prefer_rgb_color\":true, \"adapt_brightness\":true, \"adapt_color\":true, \"transition\":5}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1050,"y":480,"wires":[[]]},{"id":"c11bb00b.50dfb","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
