Hi, for a while I’ve been running an integration based around a FLIRC IR receiver which allows me to use my Harmony hub to control a WiiM streamer - indeed, that’s my main if not sole use of Home Assistant. I picked up how to do this from various sources on the WiiM forum and from sites like Controlling Home Assistant with an Old Remote – The Helpful Idiot as well as getting snippets of code and hints in this forum. I have programmed with Fortran, COBOL etc a good few decades ago and of late dabbled a bit with Excel macros and code scavenged on the 'net, but admit to finding YAML opaque and frustrating.
My automations.yaml and configuration.yaml files as are below.
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
recorder:
purge_keep_days: 5
commit_interval: 30
keyboard_remote:
- device_name: 'flirc.tv flirc Keyboard'
type: 'key_down'
- device_descriptor: /dev/input/event0
type: 'key_down'
shell_command:
wiim_ultra_pause_toggle_25: curl -k https://192.168.1.106/httpapi.asp?command=setPlayerCmd:onepause
wiim_ultra_play_preset1_2: curl -k https://192.168.1.106/httpapi.asp?command=MCUKeyShortClick:1
wiim_ultra_play_preset2_3: curl -k https://192.168.1.106/httpapi.asp?command=MCUKeyShortClick:2
wiim_ultra_play_preset3_4: curl -k https://192.168.1.106/httpapi.asp?command=MCUKeyShortClick:3
wiim_ultra_play_preset4_5: curl -k https://192.168.1.106/httpapi.asp?command=MCUKeyShortClick:4
wiim_ultra_play_preset5_6: curl -k https://192.168.1.106/httpapi.asp?command=MCUKeyShortClick:5
wiim_ultra_play_preset6_7: curl -k https://192.168.1.106/httpapi.asp?command=MCUKeyShortClick:6
wiim_ultra_play_preset7_8: curl -k https://192.168.1.106/httpapi.asp?command=MCUKeyShortClick:7
wiim_ultra_play_preset8_9: curl -k https://192.168.1.106/httpapi.asp?command=MCUKeyShortClick:8
wiim_ultra_play_preset9_10: curl -k https://192.168.1.106/httpapi.asp?command=MCUKeyShortClick:9
wiim_ultra_previous_48: curl -k https://192.168.1.106/httpapi.asp?command=setPlayerCmd:prev
wiim_ultra_next_33: curl -k https://192.168.1.106/httpapi.asp?command=setPlayerCmd:next
wiim_ultra_stop: curl -k https://192.168.1.106/httpapi.asp?command=setPlayerCmd:stop
wiim_ultra_volume: curl -k https://192.168.1.106/httpapi.asp?command=setPlayerCmd:vol:50
wiim_ultra_mute_66: curl -k https://192.168.1.106/httpapi.asp?command=setPlayerCmd:mute:1
wiim_ultra_unmute: curl -k https://192.168.1.106/httpapi.asp?command=setPlayerCmd:mute:0
wiim_ultra_shutdown_28: curl -k https://192.168.1.106/httpapi.asp?command=setShutdown:0
rest_command:
lms_ultra_play_clyde2:
url: http://192.168.1.154:9000/Default/plugins/Favorites/index.html?sess=1&index=0&player=c0%3Af5%3A35%3Adc%3Aee%3A5f&action=play
method: GET
#### automations.yaml
alias: WiiM Ultra flIRc
description: Run WiiM API calls from remote
- platform: event
event_type: keyboard_remote_command_received
event_data:
key_code: 25
- platform: event
event_data:
key_code: 2
- platform: event
event_data:
key_code: 3
- platform: event
event_data:
key_code: 4
- platform: event
event_data:
key_code: 5
- platform: event
event_data:
key_code: 6
- platform: event
event_data:
key_code: 7
- platform: event
event_data:
key_code: 8
- platform: event
event_data:
key_code: 9
- platform: event
event_data:
key_code: 10
- platform: event
event_data:
key_code: 48
- platform: event
event_data:
key_code: 23
- platform: event
event_data:
key_code: 33
- platform: event
event_data:
key_code: 66
- platform: event
event_data:
key_code: 28
condition: []
- choose:
- conditions:
- condition: trigger
id:
- "25"
sequence:
- service: shell_command.wiim_ultra_pause_toggle_25
metadata: {}
data: {}
- conditions:
id:
- "2"
sequence:
- service: shell_command.wiim_ultra_play_preset1_2
- conditions:
id:
- "3"
sequence:
- service: shell_command.wiim_ultra_play_preset2_3
- conditions:
id:
- "4"
sequence:
- service: shell_command.wiim_ultra_play_preset3_4
- conditions:
id:
- "5"
sequence:
- service: shell_command.wiim_ultra_play_preset4_5
- conditions:
id:
- "6"
sequence:
- service: shell_command.wiim_ultra_play_preset5_6
- conditions:
id:
- "7"
sequence:
- service: shell_command.wiim_ultra_play_preset6_7
- conditions:
id:
- "8"
sequence:
- service: shell_command.wiim_ultra_play_preset7_8
- conditions:
id:
- "9"
sequence:
- service: shell_command.wiim_ultra_play_preset8_9
- conditions:
id:
- "10"
sequence:
- service: shell_command.wiim_ultra_play_preset9_10
- conditions:
id:
- "48"
sequence:
- service: shell_command.wiim_ultra_previous_48
- conditions:
id:
- "23"
sequence:
- service: rest_command.lms_ultra_play_clyde2
response_variable: clyde2
- conditions:
id:
- "33"
sequence:
- service: shell_command.wiim_ultra_next_33
- conditions:
id:
- "66"
sequence:
- service: shell_command.iim_ultra_mute_66
- conditions:
id:
- "28"
sequence:
- service: shell_command.wiim_ultra_shutdown_28
mode: single
I’ve a few issues I’d like to resolve:
I’d like to simplify the YAML as the repetitive triggers and actions are calling out for a more compact sequence, if possible. For example, in the trigger section, can I have one trigger that sets “Id” to the keycode detected rather than the repeated sequence I have of “if keycode is x, set id to x elseif keycode is y set id to y elseif etc etc”?
Similarly in the action part, can I have a compact action that runs the corresponding shell command as a variable e.g. run the shell command "service: ‘shell_command.wiim_ultra_pause_toggle_’ + Id " or similar, if you follow me. I appreciate I’d need to simplify the shell command list in the configuration.yaml to rename them appropriately as shell_command.wiim_keycode_x, y etc. This would just be for a specified set of keycodes.
Also, given that not all the keycodes I might use will have a corresponding WiiM API call (like volume up/down, or easily ascertaining the current volume), I may need to use media_player service requests for them, for example this snippet:
action: media_player.volume_set
metadata: {}
volume_level: >-
{{ state_attr('media_player.wiim_ultra_ee5f_2', 'volume_level') | float +
0.02 }}
entity_id: media_player.wiim_ultra_ee5f_2
I’d also want to extend this to allow me to change which player I want the commands to apply to, so I’d need the API call IP address and the media_player device name to be variable.
If I were to express this in non YAML pseudo code (please forgive the jumble), it’d be something along these lines:
IP_addr = '192.168.1.106'
Device_name = 'wiim_ultra_ee5f_2'
Array API_keycodes = {25, 2, 3, 48, 28,...}
Array API_calls = {'setPlayerCmd:onepause', 'MCUKeyShortClick:1', 'MCUKeyShortClick:2', 'setPlayerCmd:prev', 'setShutdown:0', ...}
If keypress detected then
set Id to keypress
If Id is in API_keycodes then run shell command " 'curl -k https://' + IP_addr + '/httpapi.asp?command=' + API_calls(Match(Id,API_keycodes))"
Elseif Id = 67 then run media_player.volume_set for corresponding Device_name # for when there isn't a corresponding API call
Elseif Id = 92 then IP_Addr = '192.168.1.108' ; Device_name = 'wiim_amp_ultra' # swap device
Elseif Id = 93 then IP_Addr = '192.168.1.106' ; Device_name = 'wiim_ultra_ee5f_2' #swap device
Endif
Endif
Is this feasible in Home Assistant/ YAML?
