The 2021.11.0 update provides a new way to integrate with SimpliSafe including step-by-step instructions outlining the proper integration method. Unfortunately, my results do not match the instructions. After receiving the verification email from SimpliSafe, I do not receive an error page but rather a verification successful page. There is no code on the first web page as per the instructions. There is a code on the second web page, however, entering this code in the HA integration page results in a verification failed message.
I’ve tried this from my desktop browser as well as my Android phone with the same results.
I’ve restored my 2021.10.7 environment as that continues to work with SimpliSafe.
This isn’t working for me.
When I enter the 6 digit code, the and hit “continue” the page just stops responding.
I tried going to the developer tools “Console” and it was empty – no errors.
Thanks, @ingrove! It didn’t initially work correctly for me because Firefox gives the error:
The character encoding of the plain text document was not declared. The document will render with garbled text in some browser configurations if the document contains characters from outside the US-ASCII range. The character encoding of the file needs to be declared in the transfer protocol or file needs to use a byte order mark as an encoding signature.
This error prevented FF from processing the https://auth.simplisafe.com/continue?state=(removed) URL and displaying the code. Fortunately Edge processed the URL. It also wouldn’t continue because:
Failed to launch '(URL)' because the scheme does not have a registered handler. That (URL) contained the code that allowed me to authenticate.
I tried Firefox on Linux and Firefox doesn’t give you the code. I ended up getting to to work by using chrome on Windows. I also had problems with chrome on Linux.
