Simplisafe Rrefresh Error
Every time I try to get SimpliSafe integrated into Home Assistant, I keep getting this error.
Logger: homeassistant.config_entries
Source: components/simplisafe/init.py:357
First occurred: 8:35:41 PM (3 occurrences)
Last logged: 8:42:13 PM
Error setting up entry 6161121 for simplisafe
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 372, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/simplisafe/__init__.py", line 357, in async_setup_entry
    api = await API.async_from_refresh_token(
  File "/usr/local/lib/python3.10/site-packages/simplipy/api.py", line 154, in async_from_refresh_token
    await api.async_refresh_access_token()
  File "/usr/local/lib/python3.10/site-packages/simplipy/api.py", line 406, in async_refresh_access_token
    self._save_token_data_from_response(token_data)
  File "/usr/local/lib/python3.10/site-packages/simplipy/api.py", line 258, in _save_token_data_from_response
    self.refresh_token = token_data["refresh_token"]
KeyError: 'refresh_token'
Any help would be appreciated!
Thanks!
