The SimpliSafe “Set system properties” doesn’t seem to work for non-admin users. The standard home/away/disarm commands work fine, just set system properties doesn’t appear to work. For context, this is included in a script allowing non-admins (i.e. certain family members) to easily configure certain options within the home without giving them full access to the SimpliSafe app.
Here’s what I see in the debug log:
2023-05-20 09:42:44.513 ERROR (MainThread) [homeassistant.components.script.SCRIPT_NAME_HERE] SCRIPT_NAME_HERE: Error executing script. Unauthorized for call_service at pos 1: Unauthorized
2023-05-20 09:42:44.519 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 463, in _async_run
return await self.script.async_run(script_vars, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1533, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 410, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 454, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 477, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 452, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 685, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1849, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1889, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 870, in admin_handler
raise Unauthorized(context=call.context)
homeassistant.exceptions.Unauthorized: Unauthorized
2023-05-20 09:42:45.767 ERROR (MainThread) [homeassistant.components.script.SCRIPT_NAME_HERE] SCRIPT_NAME_HERE: Error executing script. Unauthorized for call_service at pos 1: Unauthorized
2023-05-20 09:42:45.773 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
raise exception
await service_task
task.result()
