Simulate card tap to perform action
I have a strange problem. For context: I have a led rail with 4 GU10 spots from the brand Hombli (wifi) and 2 from Gledopto (Zigbee). These are controlled by a smart switch which is behind my dumb switch. The switch does nothing in fact, but activates an automation in HA, which switches the spots on or off. Apart from some color difference, this works fine.
However, the Gledopto spots show strange behavior regarding switching off. When I use the switch, the Hombli spots switch off properly, but the Gledopto spots do nothing, or they switch on again almost immediately.
To make a long story short, I have tried everything within my automation, such as merging the spots into a group, splitting them, switching them off in steps, etc. but none of this works.
However, there is one way when I do get it working. That is to dim the spots via the Mushroom Light Card that I use, first to 1% and then to turn them off by pressing the card.
Even when I imitate the above by using the same function (switch), it does not work.
So my final question: does anyone know if it is possible to simulate pressing the Mushroom Card? I am about to throw these spots in the trash.
Sounds like a rapid firing switch.
Try to set the automation to only alone a single running instance and then add a 1 sec delay in the end.
