I’m trying to find a way to use the Amazon Smart Plugs in HA and as part of another conversation, someone suggested setting up a simulated sensor in HA which would be seen in Alexa. I’ve created a sensor according to the instructions and this is what I have in my configuration.yaml file:
- platform: simulated
name: 'simulated relative humidity'
unit: '%'
amplitude: 0 # Turns off the periodic contribution
mean: 50
spread: 10
seed: 999
relative_to_epoch: false
However, this doesn’t appear in Alexa. After installing the Alexa skill for HA and discovering new devices, Alexa picked up everything from HA, including my Hive sensors which weren’t showing previously, so I know that much is working.
The idea, I think is that I will use the dummy sensor in a routine on Alexa. So, I’ll use HA to change the state of the sensor when at sunset. This should trigger the routine in Alexa and turn on the Amazon smart plugs.
Does this look feasible, and can someone point me in the right direction for creating this simulated sensor so that it appears in Alexa.
I’m on the trial for HA cloud and would happily pay for it if I can get this working.
