Hey there,
I want to create some kind of component which helps me a bit with my Niu NQi Sport Battery (eScooter).
The eScooter can be charged directly by plugging a cable into it. Thats not the way I am charging it, as I dont have a electricity in the garage and thus, I have to unplug the battery from the scooter and charge it somewhere else.
When the battery is unplugged, I have a sensor where the last known percentage of it is exposed until the battery is re-plugged.
So I have the “last known state” available. I want to have some kind of sensor, which I can use to simulate the natural discharge of an unused lithium battery.
I think this can be done with Node-Red or an automation where I subtract a specific amount of “percent” every X Minutes/Hours.
So this might help me to determine when I have to charge the battery so it does not drop down to 0% which causes harm to a lithium battery.
So, the next step would be: when I plug the charger into the Battery, I want to trigger an automation or flow in Node-Red which handles the charging. I need to know how long it takes to charge 1% of the Battery when it is not being used (when charging it within the scooter, this might take a bit longer as it consumes power for the ECU - control unit which provides GPS and stuff).
As far as I know, lithium batteries are being charged quite quickly when they’re charged less than 80%? So I probably need some kind of logarithmic logic to raise the percentage…
As you can see, its not that simple to have a simulating component for charge and discharge of a lithium battery.
Did anyone else already had similar ideas regarding this topic?
Does anyone have other ideas?
Heading forward to your feedback!
