I was on the home assistant beta channel and received an update on the 4th of October Since then unfortunately, my victoriametrics add-on does not start anymore with the configuration that used to work for months. I can’t really find out what’s wrong as the VM log does not show anything particular (see further down). However, I can find entries in the log file that show login issues. How can I fix this with my plain vanilla configuration taken over from the documentation?
homeassistant.components.influxdb] Cannot connect to InfluxDB due to 'HTTPConnectionPool(host='homeassistant.local', port=8428): Max retries exceeded with url: /write?db=home_assistant (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f5f135e50>: Failed to establish a new connection: [Errno 22] Invalid argument'))'. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible. Retrying in 60 seconds.
Log file:
s6-rc: info: service s6rc-oneshot-runner: starting s6-rc: info: service s6rc-oneshot-runner successfully started s6-rc: info: service fix-attrs: starting s6-rc: info: service fix-attrs successfully started s6-rc: info: service legacy-cont-init: starting s6-rc: info: service legacy-cont-init successfully started s6-rc: info: service legacy-services: starting s6-rc: info: service legacy-services successfully started [06:52:32] INFO: Starting Victoria Metrics with retention set to 99y [06:52:32] INFO: Starting Victoria Metrics with args set to 2023-10-10T04:52:32.929Z info VictoriaMetrics/lib/logger/flag.go:12 build version: victoria-metrics-20231002-214442-tags-v1.94.0-0-gf13a96f42 2023-10-10T04:52:32.932Z info VictoriaMetrics/lib/logger/flag.go:13 command-line flags 2023-10-10T04:52:32.933Z info VictoriaMetrics/lib/logger/flag.go:20 -retentionPeriod="99y" 2023-10-10T04:52:32.933Z info VictoriaMetrics/lib/logger/flag.go:20 -storageDataPath="/share/victoria-metrics-data" 2023-10-10T04:52:32.933Z info VictoriaMetrics/app/victoria-metrics/main.go:70 starting VictoriaMetrics at ":8428"... 2023-10-10T04:52:32.936Z info VictoriaMetrics/app/vmstorage/main.go:108 opening storage at "/share/victoria-metrics-data" with -retentionPeriod=99y 2023-10-10T04:52:32.953Z info VictoriaMetrics/lib/memory/memory.go:42 limiting caches to 2386204262 bytes, leaving 1590802842 bytes to the OS according to -memory.allowedPercent=60 2023-10-10T04:52:33.265Z info VictoriaMetrics/app/vmstorage/main.go:122 successfully opened storage "/share/victoria-metrics-data" in 0.328 seconds; partsCount: 211; blocksCount: 61659; rowsCount: 13829967; sizeBytes: 31961533 2023-10-10T04:52:33.278Z info VictoriaMetrics/app/vmselect/promql/rollup_result_cache.go:114 loading rollupResult cache from "/share/victoria-metrics-data/cache/rollupResult"... 2023-10-10T04:52:33.292Z info VictoriaMetrics/app/vmselect/promql/rollup_result_cache.go:142 loaded rollupResult cache from "/share/victoria-metrics-data/cache/rollupResult" in 0.014 seconds; entriesCount: 0, sizeBytes: 0 2023-10-10T04:52:33.296Z info VictoriaMetrics/app/victoria-metrics/main.go:80 started VictoriaMetrics in 0.359 seconds 2023-10-10T04:52:33.296Z info VictoriaMetrics/lib/httpserver/httpserver.go:96 starting http server at http://127.0.0.1:8428/ 2023-10-10T04:52:33.296Z info VictoriaMetrics/lib/httpserver/httpserver.go:97 pprof handlers are exposed at http://127.0.0.1:8428/debug/pprof/
retention: 99y
additionalArguments: ""
enableHTTPAuth: false
username: ""
password: ""
enablePrometheusScrape: false
prometheusScrapeHTTPS: false
prometheusScrapeInterval: 20s
prometheusScrapeTimeout: 15s
longelivedToken: ""
homeassistantUrl: ""
# Prometheus
prometheus:
namespace: hass
component_config_glob:
sensor.*_bat:
override_metric: battery_percent
filter:
include_domains:
- sensor
exclude_entity_globs:
# - sensor.waqi*
- climate.refrigerator*
# Victoria Metrics InfluxDB
influxdb:
api_version: 1
host: homeassistant.local
port: 8428
max_retries: 3
measurement_attr: entity_id
tags_attributes:
- friendly_name
- unit_of_measurement
ignore_attributes:
- icon
- source
- options
- editable
- min
- max
- step
- mode
- marker_type
- preset_modes
- supported_features
- supported_color_modes
- effect_list
- attribution
- assumed_state
- state_open
- state_closed
- writable
- stateExtra
- event
- friendly_name
- device_class
- state_class
- ip_address
- device_file
- unitOfMeasure
include:
domains:
- sensor
- binary_sensor
- light
- switch
- cover
- climate
- input_boolean
- input_select
- number
- lock
- weather
exclude:
entity_globs:
- sensor.clock*
- sensor.date*
- sensor.glances*
- sensor.time*
- sensor.uptime*
- sensor.dwd_weather_warnings_*
- weather.weatherstation
- binary_sensor.*_smartphone_*
- sensor.*_smartphone_*
- sensor.adguard_home_*
- binary_sensor.*_internet_access
