Hi all,
I was initially following the steps in the below thread from 6 years ago, as this seems closely related to the issue I’m having:
I’ve already added a comment on this thread, however what I am trying to achieve is to re-upload my static IPv4 settings via a file stored on my USB drive (plugged in to the desktop running Home Assistant and Pihole), but later found that the button to “Import from USB” was removed in a 2023 update.
Have then tried since to do an import using the Home Assistant CLI and use command “ha os import”, but returns with this error:
Error: ‘OSManager.config_sync’ blocked from execution, no Home Assistant OS available
Not sure what I’m doing wrong, but happy to share logs or the system details if needed - please let me know.
I’m using a Lenovo SFF desktop which is running Debian 12 and Home Assistant Supervised, version 2024.10.3. Pihole is also running in tandem on the same machine.
Integration components include my Reolink cameras not picking up any feeds using the Frigate cards, Google Home devices are showing as unavaliable and one of my LED strips which was on Home Assistant no longer works.
Any advice is greatly appreciated. Thank you!
