I have a number of zigbee devices working with a Conbee II Zigbee hub, including Tradfri bulbs, Tradfri sockets and an Osram bulb. They have all been working fine with automations, scenes, dashboards, etc.
However since the upgrade to HA 22.5.0 and continuing with 22.5.1 there is a strange behaviour: All my automations and scenes are continuing to run, except for switching off a Tradfri socket using a scene.
I tried creating a new scene which had a single Tradfri socket set to ‘off’ and the behaviour was the same as with existing, more complex scenes: the scene will not switch off the socket.
Is this the right place to be asking this, or do I need to create a bug report in Github (I’ve never tried to do that before).
It was not listed under breaking changes for Home Assistant core but if you are using any Blueprints then each blueprint may have to be fixed and updated due to changes in ZHA and its dependencies.
Because root of such bugs are in the blueprint no breaking changes was listed for Home Assistant core.
Are you sure this is related to just the blueprints?
Because my HVAC heating via eurotronic devices also do not work anymore. Not with the blueprints and the automations and even not in the GUI or via developer tools.
