Since Updating to 0.71 Z-Wave devices respond erratically
Since I updated to 0.71 without any other configuration changes I started getting erratic behavior from my z-wave devices.
Examples:
  • Will turn on from Overview or voice device (Echo Dot) but not turn off.
  • Some devices will turn off and on as per commanded for about 10 to 15 times and then not work at all unless Hassio rebooted.
  • If I used a group command to turn on devices, they will no longer respond after the first state change.
  • A couple of devices will respond to a command to turn on or off after about 5 minutes. But then not respond again.
Z-Wave Inventory:
5 Jasco (GE) switches.
1 Jasco (GE) outlet (switch)
1 Jasco (GE) dimmer (light)
1 GoControl dimmer (light)
1 Inovelli dimmer (light)
1 Jasco (GE) fan
This only has affected the z-wave switches and lights.
There were no pre-0.71 back-ups because that would have been smart.
Tried hot and cold rebooting.
Updated to 0.72.1.
Non z-wave products are working fine.
Since I never had problems before now I never looked at the logs but when I give a command, I get entries like this:
2018-06-26 19:15:44.743 Detail, WriteMsg CAN m_currentMsg=00000000
2018-06-26 19:16:26.736 Detail,   Received: 0x01, 0x07, 0x00, 0x13, 0x90, 0x01, 0x10, 0x6a, 0x00
2018-06-26 19:16:26.736 Detail,   ZW_SEND_DATA Request with callback ID 0x90 received (expected 0x00)
2018-06-26 19:16:26.736 Warning, WARNING: Unexpected Callback ID received
